12v reverse speed control circuit diagram
3 replies · 9K views · last reply
terencep
Hi
I have a 9v motor (can run to 24v). I need to control the speed of the motor and reverse the direction. I also wanted to control it with a duel-potentiometer, but i can't seem to find any way to do this. can someone help with a circuit diagram please?
(This is my first time building a circuit so any help you can offer please)
Thanks
Terence
This shows a circuit that looks like what you need.
http://www.dprg.org/tutorials/2005-11a/index.html Note that the output is taken from pin 7 which is unusual but OK in this circuit. Pin 3 is normally the output of a 555.
That would give you variable speed and you would need a Double pole double throw switch to change the polarity of the voltage getting to the motor to reverse its direction.
The motor would be on the right and the input voltage on the left in this diagram.
This National Semiconductor LMD-18200 full H-bridge offers full 3-amp 24-volt forward-reverse pulse width modulation w/braking.You can probably use the PWM to control different motor speeds in forward and reverse. You can also do it with diodes and pots on the output.
http://acroname.com/robotics/parts/R27-18200.pdf
Tell us more about the motor rating.
