12v to power household appliances?
  • Thread starter Thread starter jagman454
    12v Power
To power household appliances like computers and TVs with a 12v battery, an inverter is necessary, as these devices typically require 100v from a standard outlet. A sine wave or modified sine wave inverter is recommended for compatibility with electronic equipment. Deep cycle batteries are ideal for this purpose, providing longer usage times, but running appliances for extended periods will require a significant investment in batteries. Inverters can range in power from 400 watts to 2000 watts or more, with prices varying by supplier. For reliable options, specialized retailers and RV dealers are good sources for purchasing inverters.
jagman454
12v to power household appliances??
How can I use a 12v battery to power household appliances such as computers/TV ect...
Do I need some type of converter? I was told that a 12v battery won't power household appliances because they are designed to run off of the 100v house circuit. Where should I start?
Welcome to PF, Jagman.
You need an inverter, not a converter. Most automotive supply places can set you up with one. They're a bit pricey, but not too bad if you really need one. Only problem is, the biggest one that Canadian Tire sells is 400 watts. It costs $60. I don't know about other suppliers. RV dealers might have something bigger.
In addition to what Danger said.
Most electronic equipment is not real happy with plain inverters.
You are going to want a Sine Wave or Modified Sine Wave inverter.
The average computer or TV might run 30 minutes to an hour on a large deep cycle battery like they sell for boats in the auto supply store.
The "Deep Cycle" part is important if you want the battery to last a while.
You can get inverters up to 2000 Watts, but to run one for any length of time is going to be a major investment in batteries.
http://www.invertersrus.com/
Check these people out, i have bought 1- 5000Watt, and 2- 2500Watt, inverters from them and have been pleased with all units. At the time, they came with cables(4 on the 5K) and were, sales tax and freight free. (i have had no problems with any units)
Before finding this source, i bought a Vector 3000Watt, and a couple of smaller units, they required sales tax and cables
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
