12VDC/2A power adapter to power two systems?
A user seeks to power a Raspberry Pi (5V/1.2A) and a 12V LCD monitor using a single 12VDC/2A power adapter. They plan to use an LM317T voltage regulator to step down the voltage for the Raspberry Pi. It is advised that the LM317T should be well heat-sinked due to significant heat dissipation, especially since it operates near its maximum capacity. Alternatives like using a buck converter for better efficiency and lower heat concerns are also suggested. Overall, the proposed solution is feasible with proper considerations for heat management and component selection.
perplexabot
Hey!
So I have a raspberry pi that uses 5V/1.2A and a LCD monitor that uses 12v/0.2A. I would like to power both using a single wall power outlet. I found a power adapter that converts 100-240VAC/50-60Hz/1.2A to 12VDC/2A.
I was wondering if it is as easy as cutting off the connector on the other side of the adapter, and using the +12/-12 wires to power the LCD (which I'm sure would work), then I would also tap the +12/-12 wires to a LM317T so that it outputs a regulated voltage of 5V (to the pi).
Will this work?
Thanks.
Will this work?
yup ... ensure the 317 is well heat sunk ... it's going to dissipate a lot of watts of heat
namely 7 x 1.2A = 8.4W
edit ... also note that @ 1.2A that is right near the max for the LM317 ... best to use the TO3 case not the TO220 case version
Likes perplexabot
Thank you for the quick reply! Great to hear it is that simple! Unfortunately now I have to solder together a new circuit for the TO3 instead of using an older circuit i had with the TO220.
Oh well, shouldn't be too bad. Thanks again.
EDIT: DAMN! Those TO3's are 40 bucks on digikey!
Thread 'I thought it was only Amazon that sold unsafe junk'
I grabbed an under cabinet LED light today at a big box store. Nothing special. 18 inches in length and made to plug several lights together. Here is a pic of the power cord: The drawing on the box led me to believe that it would accept a standard IEC cord which surprised me. But it's a variation of it. I didn't try it, but I would assume you could plug a standard IEC cord into this and have a double male cord AKA suicide cord. And to boot, it's likely going to reverse the hot and...
