12VDC/2A power adapter to power two systems?
The discussion revolves around the feasibility of using a 12VDC/2A power adapter to power both a Raspberry Pi and an LCD monitor. Participants explore the method of using the adapter to supply power directly to the LCD while also employing a voltage regulator to step down the voltage for the Raspberry Pi.
  • One participant proposes cutting off the connector of the power adapter to use the +12/-12 wires for powering the LCD and suggests using an LM317T to regulate the voltage down to 5V for the Raspberry Pi.
  • Another participant agrees with the initial proposal but emphasizes the importance of ensuring the LM317T is adequately heat sunk due to significant heat dissipation, calculating it to be around 8.4W.
  • A later reply mentions that operating the LM317T at 1.2A is close to its maximum rating and recommends using the TO3 case for better thermal management over the TO220 case.
  • One participant expresses frustration over the high cost of TO3 components, while another counters with a suggestion to consider a more efficient eBay buck converter as an alternative, which would eliminate the need for a heatsink.
Participants generally agree on the method of using the power adapter and LM317T, but there are differing opinions on the best components to use and the associated costs, indicating some unresolved preferences regarding the implementation.
Participants discuss the thermal management of the LM317T and the implications of using different component cases, highlighting the importance of efficiency and cost in selecting components for the circuit.
perplexabot
Hey!
So I have a raspberry pi that uses 5V/1.2A and a LCD monitor that uses 12v/0.2A. I would like to power both using a single wall power outlet. I found a power adapter that converts 100-240VAC/50-60Hz/1.2A to 12VDC/2A.
I was wondering if it is as easy as cutting off the connector on the other side of the adapter, and using the +12/-12 wires to power the LCD (which I'm sure would work), then I would also tap the +12/-12 wires to a LM317T so that it outputs a regulated voltage of 5V (to the pi).
Will this work?
Thanks.
Will this work?
yup ... ensure the 317 is well heat sunk ... it's going to dissipate a lot of watts of heat
namely 7 x 1.2A = 8.4W
edit ... also note that @ 1.2A that is right near the max for the LM317 ... best to use the TO3 case not the TO220 case version
Thank you for the quick reply! Great to hear it is that simple! Unfortunately now I have to solder together a new circuit for the TO3 instead of using an older circuit i had with the TO220.
Oh well, shouldn't be too bad. Thanks again.
EDIT: DAMN! Those TO3's are 40 bucks on digikey!
