2 Plane mirror problems. no numbers
In the discussion about two plane mirror problems, participants explore how many images can be seen with mirrors positioned on the x and y axes, concluding that three images are formed due to reflections. The second problem addresses the minimum height of a mirror required for a person to see their full reflection, with the answer determined to be half the person's height. Participants express confusion over the reasoning behind these concepts, particularly regarding ray diagrams and the relationship between image size and mirror height. Clarifications emphasize that the virtual image size equals the actual size, and the height of the mirror only needs to be half to reflect the entire body. The conversation highlights the importance of understanding ray diagrams and the principles of reflection in solving these problems.
phillyj
#1) How many images can be seen? 2 mirrors, one on x axis, other y axis.
Law of reflection: \varthetai=\varthetar
Is the positioning correct? I thought that rays bounce off the x-axis mirror then y-axis mirror to give 2 images. The third image came from bouncing off the y-axis mirror only. The teacher wanted us to work it out and told us that the answer is 3 but we had to find the position.
______________________________________________________________________________
#2) Whats the minimum length(h) of a mirror that is needed for a person of height(H) to see his entire reflection? Answer: h=H/2
|m|= |H/h| <= magnification equation needed?
I'm not sure how to start. Professor said that the distance between the person and mirror doesn't matter. Someone point me in right direction
1) Position of image 2 in not correct. Its distance from the axis should be equal to the remaining two images.
2) Draw ray diagram, one from eye and other from foot. Note down the portion of mirror to see the full image.
1) Ok, but my reasoning is correct?
2) I'm not sure how to draw from eye.
1) Yes.
2) Draw the ray from head to eye.
2) from top of the head to the eye? the angle of reflection would be very very small? I still can't get this part
When you want to your full image, you must see your head and toe. If you want you can take a normal ray from your eye. After reflection it returns back to your eye.
for plane mirrors, isn't the virtual image equal size to the actual image? Magnification=+1
So why is the height of the mirror H/2?
Size of the image does not depend on the size of the mirror. Even in a small mirror you can see your full face.
ok, but when I try drawing it, my virtual image is the same size as the actual. Was the partial drawing that I made above correct? I still can't understand how to draw ray from top of head to the eye.
You know of any websites that could help?
