Coulomb's Law Question with Charges on x-axis
Three point charges are positioned on the x-axis: +2.0 micro Coulombs at x=0, -3.0 micro Coulombs at x=40 cm, and -5.0 micro Coulombs at x=120 cm. The forces acting on the -3.0 micro Coulomb charge from the other two charges were calculated using Coulomb's Law, resulting in -0.3375 N from the +2.0 micro Coulomb charge and 0.2109 N from the -5.0 micro Coulomb charge. The discrepancy with the book's answer of -0.55 N arises from confusion over how to combine these forces, particularly regarding their directions. A free body diagram is recommended to visualize the forces, which both act towards the left, indicating attraction and repulsion. Understanding the polarity of charges is crucial for accurately determining the net force on the -3.0 micro Coulomb charge.
Sabellic
Three point charges are placed at the following points on the x-axis: +2.0 micro Coulombs at x=0; -3.0 micro Coulombs at x=40 cm; and -5.0 micro Coulombs at 120 cm. Find the force on the -3.0 micro Coulomb charge.
Coulomb's Law:
Fe= k * qq' / r^2
For 2.0 microC charge to the -3.0 microC charge:
Fe= (9.0 * 10^9) * (2.0 * 10^-6)(-3.0 * 10^-6) / 0.40^2
= -54 * 10^-3 / 1.6 * 10^-1
= -0.3375 N
For -5.0 microC charge to the -3.0 microC charge:
Fe= (9.0 * 10^9) * (-5.0 * 10^-6)(-3.0 * 10^-6) / 0.80^2
= 135 * 10^-3 / 6.4 * 10^-1
= 0.2109 N
The book says the answer is -0.55 N. But I thought that with this procedure we are supposed to use the absolute values. I don't understand which Fe I should be subtracting from the other. Please help me.
For the magnitude it is the absolute value but the direction (negative or positive depends on your axis). Draw a free body diagram..
Between the +2.0 and the -3.0 charge, the force acts towards the left because of an attraction whereas between the -3.0 charge and the -5.0 charge, the force acts towards the left too because of repulsion. Therefore you should draw a free body diagram to see how the forces of attraction and repulsion add up.
In considering the electrostatic force of attraction, you cannot consider the directional values of the force and the polarity of the charges. You can only start to consider the polarity of charges when considering electric field strength, in which it is a vector and the polarity will tell you the direction of the electric field strength.
