What is the Electrostatic Force on Particle 3 in a Triangular Configuration?
The discussion centers on calculating the electrostatic force on particle 3 in a triangular configuration of charged particles. Particle 1 has a charge of 80 nC and is positioned at (0, 3.00 mm), while particle 2's charge can be either 80 nC or -80 nC at (0, -3.00 mm), with particle 3 at (4.00 mm, 0). The book provides the answers for the forces on particle 3 as (a) 0.829 N in the i direction and (b) -0.621 N. The participant struggles to replicate these results despite multiple attempts and calculations involving the distance and angles between the particles. Clarifications are made regarding the correct distances and the need to use the appropriate charges in the calculations.
jmckennon
Three charged particles form a triangle: particle 1 with charge Q1=80nC is at xy coordinates (0,3.00mm) particle 2 with charge q2 is at (0,-3.00mm) and particle 3 is at(4.00mm,0). In unit vector notation, what is the electrostatic force on particle 3 due to the other two particles if Q2 is equal to (a) 80.0 nC and (b) -80nC?
The book lists the answers as: (a).(0.829N)i and (b) (-.621N).
F= (|Q1||Q2|*K)/r^2
k=permittivity constant 8.99x10^9
r= distance between the charges
theta= arctan(y/x)
I have tried countless different ways to do it and can't seem to get the book's answer. I have played around with the numbers for over 3 hours and haven't found anything that works. Any help would be GREATLY appreciated as I have no idea how close or far away I am.
The last way I tried it was by drawing out the triangle. I found theta to be arctan(3/4)=36.869degrees
F=((.64x10^24)*8.99x10^9)/(6x10^-3)^2=159.822 nC/m^2
Fx=159.822cos(36.869)=-127.851
Fy=159.822sin(36.869)=95.89132
Fy= 159.822
sqrt((159.822+95.89132)^2+(-127.851)^2))=285.8973
I have no idea what the units are there after all that on the latest try, nor what that answer means.
What is the charge of particle #3?
F= (|Q1||Q2|*K)/r^2
What does this have to do with Q3, the particle you are asked to calculate the force for?
theta= arctan(y/x)
Yes.
q1 q2 = (.64x10^24) -- Use Q3 instead of Q2. Is the exponent really +24?
k = 8.99x10^9 -- Yes
r = (6x10^-3) -- No. You need the distance between q1 and q3, not between q1 and q2.
This will be correct once you calculate F correctly. Just keep track of whether these components are + or -.
