Designing a Digital Timer to Automate Geyser Control
The discussion focuses on designing a digital timer to automate geyser control for energy savings, emphasizing the desire to use logic ICs instead of PICs. The user seeks a timer with three preset 'on-times' and 'off-times' but receives advice suggesting a pre-built AC wall timer as a simpler solution. Concerns are raised about the legality and power capacity of homemade devices in South Africa, particularly given the high wattage of geysers. Despite these challenges, the user expresses a commitment to learning about logic ICs rather than opting for a commercial product. The conversation highlights the balance between DIY projects and regulatory considerations in electrical engineering.
Fuzigish
I want to build a digital timer that will switch my geyser on and off at a preset time in order to save power. I don’t know much about PICs so I would rather try using only logic ICs. It has to have at least 3 preset ‘on-times’ and 3 ‘off-times’. Can anyone help me to get started?
seriously, just go to the hardware store and pick up an AC wall timer. something like this:
http://www.drillspot.com/pimages/65/6526_300.jpg
maybe get a "heavy duty" unit, while you're at it. don't know how much power a "geyser" uses.
Unfortunately it would be illegal to build something like that into a distribution board in South-Africa. Plus an average geyser is 4000W – 6000W, so I don’t think even a heavy-duty unit would work.
This is an example of something similar: http://www.geyserwise.co.za/web/index.php"
a "geyser" is a hot water heater?
there are also timers that control a lot more current and could be inserted into an electrical panel. what i don't get is how it's going to be any more legal for you to insert some homemade controller into a panel. if that's your goal, you'll need to buy an approved product.
Yes, a ‘geyser’ is a hot water heater.
This whole exercise is not to build something that will necessarily be used. I just want to learn something out of this about logic-ICs, so buying a pre-built unit would be pretty useless.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
