3 Volt DC Motor Performance Graphs
Users are seeking 3 Volt DC motor performance graphs online, similar to those found on specific motor performance websites. One user provided a link to a performance graph for electric motors but noted it does not specifically cater to 3 Volt motors. Despite extensive searching, relevant results have not been found. A suggestion was made to check the Mabuchi Motor website for potentially useful information. The discussion highlights the challenge of locating specific performance data for low-voltage motors.
NSX
Does anyone know where I can find 3 Volt DC Motor Performance Graphs on the web?
I'm looking for something like this,
Cliff_J said:
Look at this performance graph for an electric motor:
http://www.greenpower.co.uk/fracpero.htm Cliff
but with a 3 Volt motor.
My googling has yet to find any relevant results.
Thanks in advance.
Try http://www.mabuchi-motor.co.jp/english/
Hi all, I have a question. So from the derivation of the Isentropic process relationship PV^gamma = constant, there is a step dW = PdV, which can only be said for quasi-equilibrium (or reversible) processes. As such I believe PV^gamma = constant (and the family of equations) should not be applicable to just adiabatic processes? Ie, it should be applicable only for adiabatic + reversible = isentropic processes? However, I've seen couple of online notes/books, and...
I have an engine that uses a dry sump oiling system. The oil collection pan has three AN fittings to use for scavenging. Two of the fittings are approximately on the same level, the third is about 1/2 to 3/4 inch higher than the other two. The system ran for years with no problem using a three stage pump (one pressure and two scavenge stages). The two scavenge stages were connected at times to any two of the three AN fittings on the tank. Recently I tried an upgrade to a four stage pump...
