3 volume via integration problems that are giving me trouble
The discussion focuses on solving three volume integration problems. For the pyramid problem, the area of cross-sections can be found by integrating the side lengths over the height. The second problem involves integrating the function y = e^(4x) + 1 from 0 to 0.5 to find the volume of the solid formed by rotation. The third problem requires using the washer method to find the volume between the curves y = x^3 and y = 25x, integrating over their intersection points. The responses clarify the integration methods needed for each problem, emphasizing the importance of correctly applying the formulas for volume.
JasonJo
my teacher never actually went over this, but i tried doing them anyway. there were 15 problems originally assigned, and i wanted to get them all done on my own before class on tuesday, I am hoping you guys can help out
12) You want to make a pyramid with height = 3260 and square base with side s=1780
a) find the integrand
b) find the volume
i know the volume of a pyramid is Bh/3, but i don't know how to get the area of the delta x and then sum infinite delta x's together
14) Find the volume of the solid formed by rotating the region enclosed by:
y= e^(4x) + 1
y = 0
x = 0
x = 0.5
15) find for the volume of the solid formed by rotating the region inside the first quadrant enclosed by
y=x^3
y=25x
do i go about finding the volume of the entire solid if i were to rotate it around and then cut it in half?
thanks a ton guys, i usually get great homework from this forum
12) If you can get the length of the sides of the pyramid at a given z-value, you can get the area of the cross-sections in terms of z. Integrate this over z.
14) Just integrate the function from 0 to 0.5.
15) I don't understand you're question about cutting it in half, but just use the washer method, integrating \pi((25x)^2-(x^3)^2) over the range between 0 and their intersection point.
12) Status is correct.
14) Integrate from 0 to 0.5 and multiply by 2Pi
15) Integrate both normally, multiply by 2Pi for the rotation, then subtract the integrals. Or equivalently, 2\pi \int{(x^3-25x)}{dx}
I'm sorry, I didn't see that you wanted the volume of the solid of rotation for 14. But I think for the solid of rotation you need to use pi r^2, not 2 pi, since you are adding up the areas of all the cross sections to get the volume.
