Load sharing in parallel vs orthogonal screws
The discussion focuses on the load distribution between parallel and orthogonal screws used in orthopedic fracture fixation. The surgeon seeks to understand how these configurations affect load sharing, particularly with interlocking screws in intramedullary nails. It is noted that the primary role of fasteners is to create clamping force rather than carry the load directly, with frictional forces playing a crucial role in joint strength. A request for visual aids, such as diagrams, is made to facilitate understanding of the geometry involved. Overall, the inquiry aims to define load distribution mathematically or engineering-wise based on screw configuration.
maveric
Hi I would be grateful for some help or pointers for the following question.
I am an orthopaedic surgeon and often when we fix fractures we use screws to hold the bone in place.
We use different configurations of screws (ie one or two parallel or orthogonal, two screws at right angles to each other) based on either the fracture pattern or sometimes we are driven to use this configuration based on the manufacturers implant designs such as in intramedullary nails, which are rods we pass into the bone to fix fractures. In intramedullary nails we pass the screws through the bone and nail in a manner that if effectively 'locks' the nail hence they are called locking screws. (http://orthopedics.about.com/cs/brokenbones/g/imrod.htm)
My question is if I am using two interlocking screws to fix a fracture how will the load be distributed between the screws if I use two parallel screws vs orthogonal screws ( screws at right angle to each other). What i am really after is can the load distribution on screws be defined based on its configuration in an engineering or mathematical sense.
I hope i make sense and any help would be appreciated.
Many thanks
It's a bit tough to understand the geometry of what you deal with so perhaps we can start with some basics about fasteners...
A fastener for a joint has one major purpose. That is to create clamping force. The fasteners are usually NOT the members that carry the load in a joint. The frictional forces created by the clamping is responsible for the strength of the joint. Granted there are always exceptions and this is definitely not an absolute. However, the clamping force created in the joint is paramount to the joint's strength and the required sizing of the fasteners.
If there is any way you can provide a basic picture or diagram to discuss, that would be a huge help.
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
