Hydrogen peroxide production in water electrolysis
Electrolysis can lead to the production of hydrogen peroxide, which occurs at the anode due to the oxidation of oxygen from a -II to a -I state. The textbook's answer aligns with this, stating that hydrogen peroxide forms at the anode. The discussion includes standard electrode potentials for relevant reactions, highlighting that while water hydrolysis reactions occur, the formation of hydrogen peroxide is linked to the oxidation of oxygen. The confusion arises from interpreting the reaction where oxygen accepts electrons to form hydrogen peroxide, which suggests a cathodic process. However, practical observations during electrolysis show that gas bubbles form at the anode, reinforcing that hydrogen peroxide production indeed takes place there. The key takeaway is that understanding the electrochemical environment and the nature of oxidation and reduction reactions is crucial for accurately determining where specific reactions occur during electrolysis.
ComptonFett
I'm trying to understand my textbook's answer to the following problem:
Q: Electrolysis can under certain circumstances result in the production of hydrogen peroxide. At which electrode will this occur, cathode or anode?
A: During the formation of hydrogen peroxide from water, oxygen is oxidized from -II state to -I state. Oxidation on the other hand takes place at the anode. Therefore hydrogen peroxide is formed at the anode.
The answer did not elaborate any further. I studied the standard electrode potentials of reactions involving hydrogen peroxide and found the following reactions:
\begin{align}
& (1)\quad 2\ H_{2}O\ (l)\to O_{2}(g)+4H^{+}+4e^{-}\quad \left[ -1.23\ V \right] \\
& (2)\quad 2\ H_{2}O\ (l)+2e^{-}\to H_{2}(g)+2\ OH^{-}\quad \left[ -0.83\ V \right] \\
& (3)\quad O_{2}+2\,H^{+}+2\,e^{-}\to H_{2}O_{2}\quad \left[ +0.70\ V \right] \\
\end{align}
Reactions (1) and (2) describe water hydrolysis, I included these just in case someone would find them helpful. Reaction (3) is the one from which I (erroneously) concluded that hydrogen peroxide production would take place at the cathode. I interpreted reaction (3) as showing that oxygen could accept electrons from the cathode and then combine with hydrogen ions to turn into hydrogen peroxide. I reckon that the hydroxide ions from the water hydrolysis could soak up any lingering oxonium ions and this way prevent reaction (3) but I'm not sure if this is the reason why my original reasoning was wrong.
I would appreciate guidance that would show me why my own attempted answer was wrong and what kind of logic I should apply to end up with the correct solution.
Chemistry news on Phys.org
I think you had the right Idea but just didn't think about it like a real system (as opposed to an equation)
I think 3 is correct but when you place the 2 wires in the water the bubbles form on the anode. When I read your question I thought it was the cathode too until I built one.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
