Ice Sled Powered by Rocket Engine: Find t1, t2, v & Final Position
The discussion focuses on solving a physics problem involving an ice sled powered by a rocket engine, which accelerates at +38 ft/s² before moving at a constant velocity. Participants suggest breaking the problem into two phases: the acceleration phase and the constant velocity phase, using kinematic equations to establish relationships between time, distance, and velocity. Key equations include the total distance traveled (15,750 ft) and total time (90 s), which lead to two equations with two unknowns. The sled's final motion involves a deceleration of -21 ft/s² after reaching the distance mark. The discussion emphasizes a step-by-step approach to derive the necessary values for t1, t2, and the sled's final position.
funwithphysics
An ice sled powered by a rocket engine starts from rest on a large frozen lake and accelerates at +38 ft/s2. After some time t1, the rocket engine is shut down and the sled moves with constant velocity v for a time t2. Assume the total distance traveled by the sled is 15750 ft and the total time is 90 s.
(a) Find the times t1 and t2.
t1
t2
(b) Find the velocity v.
ft/s
At the 15750 ft mark, the sled begins to accelerate at -21 ft/s2.
(c) What is the final position of the sled when it comes to rest?
ft
(d) What is the duration of the entire trip?
Please just show me how to do this. My entire weekend has consisted of me holed up in my basement doing physics. This is my last problem and I just want to feel happy and alive again :(
s
Welcome to PF funwithphysics!
t1
t2
ft/s
ft
s
No, please read our site rules. We won't do your homework for you here. Instead, let's go through this step by step. Start with the first phase of the motion, between t = 0 and t = t1. This is the constant acceleration portion of the trip. Write down an expression for the distance vs. time during this phase.
Next, write an expression for the distance vs. time during the second portion, between t = t1 and t = t2. This is a constant velocity portion of the trip, and you know what v is in terms of 'a' and t1.
You know that the two distances have to add up to 15,750 ft, and that the two times have to add up to 90 s.
That gives you two equations, and two unknowns. So you can solve for both of them.
OK . Your last line was funny.
From your problem
Eq 1 : t1 + t2 = 90 seconds
also, distance traveled during acceleration + distance at constant velocity v is 15750 feet
Eq 2: d1 + d2 = 15750 feet
acceleration,
Eq 3: a1 = 38 ft/s^2
Eq 4: a2 = 0
From an equation of linear motion,
x = x0 + 1/2 vt
x = x0 + v0 t + 1/2 a t^2
v = v0 + at
v^2 = v0^2 + 2 a d
Can you think how to manipulate those equations to solve for t1, t2 and v in your problem?
