How do I solve questions involving lots of theory and no calculations?
The discussion centers around a student in a grade 12 chemistry class struggling with conceptual questions despite being proficient in calculations. A specific question regarding the reaction of aluminum with oxygen to form aluminum oxide is highlighted. The question asks why the enthalpy change of this exothermic reaction is not detectable, despite a significant energy release. Participants suggest that the reaction is unnoticeable because the aluminum forms a protective oxide layer that prevents further oxidation, thus masking the enthalpy change. They also recommend demonstrating the reaction with burning aluminum powder to illustrate the concept effectively. Overall, the focus is on understanding the underlying principles of chemical reactions and enthalpy changes rather than just performing calculations.
airbusman
I'm in a grade 12 university level chem class right now, and I'm getting a 72. I realized just today that the reason why I'm doing so poorly is because I'm good at calculations, but not questions that involve even more thinking.
For instance, one question gave us some information about aluminum reacting with oxygen to form aluminum oxide, and it asked why the enthalpy of reaction for this reaction is not detectable, even though the reaction is exothermic and it has a large enthalpy change.
How would you approach questions like this?
Chemistry news on Phys.org
Actually I have no idea what the question is about, can you post a complete wording?
Here it is:
"Aluminum is a reactive, self-protecting metal used to make doors, windows, and siding for houses. It reacts quickly with O2 to form an impervious coating of aluminum oxide, that prevents O2 from reacting any further with the aluminum. This reaction is unnoticeable even though the reaction shown below indicates a large enthalpy change. Why is the enthalpy of reaction not detectable?"
4Al(s) + 3O2(g) → 2Al2O3(s) +33351.4 kJ
How thick is the oxide layer?
You should show your teacher some burning aluminium powder.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
