Savox SB2272MG Digital Servo: Precise Enough for Sinusoidal Motion?
  • Thread starter Thread starter pyroknife
    Motor Servo
The Savox SB2272MG digital servo is being considered for generating sinusoidal pitching motion from 0 to 60 degrees. Users discuss the servo's capability for precision in motion control, emphasizing the need for smooth operation that closely mimics programmed commands. Concerns are raised about the previous motor's performance, which lacked smoothness and accuracy, potentially due to hardware limitations. Questions arise regarding the definition of 0 degrees on a servo and the refresh rate of the controller used. Overall, the discussion highlights the importance of matching servo capabilities with control hardware to achieve desired motion quality.
pyroknife
I bought a Savox servo motor (http://www.savoxusa.com/Savox_SB2272MG_Digital_Servo_p/savsb2272mg.htm)
I'm planning on using the motor to generate a pitching motion sinusoidally from 0 to 60 degrees back to 0 and so on...
Do you guys think this motor is precise enough to generate the sinsusoidal motion?
Nothing about that servo prevents it from creating a sinusoidal motion. When you say precision what precision are you looking for? What do you plan to control it with?
I will be controlling it with an Arduino. On a previous motor I used (which was more expensive than this one), I used a high speed camera to videotape the motion and noticed that it was not smooth and didn't look very sinusoidal like. So by precision, I mean the motion is smooth and mimics the code very closely.
Also, does anyone know where 0 degrees is on a servo?
What was the refresh rate for the controller and how fast were you driving the motor? It could be you were driving the servo beyond the capabilities of the hardware you were using...
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
10K
