Why does nitrogen gas' pressure not change after an addition of helium
In a 9 L vessel containing 3 moles of helium and 3 moles of nitrogen at 10 atm, the initial partial pressures are calculated as 5 atm for both helium and nitrogen. When 2 additional moles of helium are added, the total number of moles increases to 11, leading to a new total pressure of approximately 12.2 atm. The partial pressure of helium is recalculated to be about 5.545 atm. However, the partial pressure of nitrogen remains unchanged because the number of nitrogen molecules has not increased. This discussion emphasizes the principles of ideal gas behavior, which assumes no intermolecular interactions and negligible particle volume, simplifying calculations. Understanding these assumptions is crucial for accurately applying the ideal gas law and recognizing when deviations may occur under different conditions.
dramadeur
a 9 L vessel contains 3 moles of helium and 3 moles of nitrogen at a pressure of 10 atm. Maintaining constant temperature, an additional 2 moles of helium are added. Assuming gases behave ideally, what are the partial pressures of nitrogen and helium at the end?
Initially there's: 3mol He/(3mol + 3mol) * 10 atm = 5 atm pressure of He
And: 3/6 * 10atm = 5 atm pressure of N2 as well
now that 2 moles of He are added to the vessel, why wouldn't N2's partial pressure increase? The way I see it, there are now more atoms, so more of them would knock on the walls, therefore pressure would increase overall, and since there are now more atoms, space between atoms is tightened, so ...
Anyway, overall pressure is P1/n1 = P2/n2
(10 atm/9 mol) = (P2/11 mol); P2 = 12.2 atm new total pressure
Partial PHe * Ptotal = 5/11 * 12.2 atm = 5.545 atm He
That's for He gas, but why shouldn't partial pressure change for N2 gas?
Chemistry news on Phys.org
There are the same amount of nitrogen molecules so the nitrogen partial pressure does not change. Your total pressure is wrong. Where did 9 and 11 come from?
This comes from the assumption of ideal gas behavior. The partial pressure of an ideal gas is the pressure of the same amount of the pure gas at the same temperature/volume as in the mixture. Ideal gases are assumed to have zero intermolecular interactions and particle volume, this greatly simplifies a lot of the mathematics and is a very good approximation to small (mon- and diatomic) gases at fairly low pressures. The greater the pressure or the larger the gas the greater the deviation from ideality which necessitates the use of "messy" http://www.chem.arizona.edu/~salzmanr/480a/480ants/VIRIAL/virial.html or Van der Waals equation to account for the intermolecular forces and non-negligible particle volume.
I'd recommend getting comfortable with the assumptions underlying the concept of an ideal gas.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
