Bernoulli's with Resistances - model flow between oil filters
The discussion centers on modeling flow between oil filters using Bernoulli's principles and resistance calculations. The user seeks to implement a two-filter setup in parallel to accommodate a higher pressure oil pump without damaging the filters. Key points include the importance of understanding the pressure drop across filters and the necessity of protecting the pump from contamination by filtering the oil before it enters the pump. It is noted that using a differential pressure gauge can help monitor filter blockage, and employing two filters in parallel can effectively double the flow for the same pressure drop. The conversation emphasizes the need for proper filtration strategies and the potential for using higher capacity filter elements.
CorneliusRox
Bernoulli's with Resistances -- model flow between oil filters
Hey guys,
It's been a while since I was in school and practicing this stuff daily, so bear with me please!
I'm a BSME and I want to model up flow between oil filters.
Currently we use a single oil filter with the same pump we have used forever.
What I am proposing is a higher pressure oil pump (more LPH really) but it will blow holes in the oil filters, so I want to use a two filter setup in parallel.
My question is, how can I model up the resistance of one filter, and then model up the same properties (constant pressure, constant density, constant height) to see how much the flow would change with the second filter.
I am assuming that I can use R=1/((1/r1)+(1/r2)) to model resistance and show that the second filter will drop. The filters are rated at a certain psi and kind of work like a regulator, but regardless, I think this still holds true.
In the end, I'll validate this through dyno and field testing, but I'd like to understand it more first.
Thanks everyone!
Welcome to PF.
Lubrication oil or hydraulic oil?
A positive displacement hydraulic pump produces a fixed volume flow. The filter will drop some pressure at that fixed flow. The filter should not be used to regulate the flow. Are you using a centrifugal pump ?
It is normal to filter the pump input from the tank, not the output of a pump. You need to protect the pump from dirt in the oil. Why are you filtering the high pressure output of the pump ?
As the filter becomes progressively blocked the differential pressure will rise. You should have a differential pressure gauge across your filters to detect blockage, well before a filter fails and dumps it's load of dirt and fragments of filter element into your system.
You can double the flow for the same differential pressure across the filter by using two filters in parallel. You can often buy replaceable filter elements with a higher capacity, they have the same screw fitting, but have longer canisters.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
