Deriving the Center of Mass of a Cone with Point Facing Downwards
To find the center of mass of a cone with its point facing downwards, the discussion focuses on using calculus to derive the center of mass formula. The cone is treated as a stack of disks, where the radius of each disk varies linearly with height. The volume of each disk is expressed as Dv = π[(r/H)x]^2 dx, leading to the integration of x from 0 to H. The calculations yield the center of mass at 3/4 H, confirming the conventional result of H/4 for the center of mass location. The integration approach emphasizes the importance of understanding the geometry and volume of the cone's structure.
dowjonez
I need to find the center of mass of a cone with point facing downwards, of height H and radius R.
Since the density is constant throughout and because of axial symmetry the center must be somewhere on the z-axis.
I know from convention that this is H/4 but i need to derive this.
Rcm = (intregral from 0 to H) of the change in radius
this is where I am stumped
i did really bad in calculus
could anyone help me?
Hint: Consider the cone as a stack of disks.
Let Dv Be An Element In The Form Of A Disk That Cuts Through The Cone.
The Radius Of The Disk Is (r / H) X.
The Volume Equals The Area Of The Disk Times The Thickness.
Dv = Pi[(r / H ) X] ^2
Now Intergate From 0 To H
X' = Int (x Dv) / Int Dv = 3/4 H
okay so the biggest such disk would have volume pi*R^2*h
what is the volume of the disk under that?
the biggest *THIN* disk, at x = H, has radius r = xR/H,
so its Volume = dV = pi R^2 dx.
You need to integrate x from 0 to H .
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
