A charge falls from infinity to within r of another charge, find velocity.
The discussion focuses on calculating the velocity of an electron falling from infinity to a distance of r = 10^-8 m from a charge q1 = 4.8 x 10^-19 C. The potential energy change is calculated using the formula U = k(q1)(q2)/r, resulting in U = 6.912 x 10^-21 J. The kinetic energy is then set equal to the potential energy to find the velocity, leading to v = (2U/m)^(0.5), which gives v = 1.23 x 10^5 m/s. Participants are encouraged to check the calculations, particularly the power of ten in the equations. The discussion aims to clarify any errors in the solution process.
User1247
Velocity of an electron that falls to r from infinity?
An electron falls from infinity to r=10^-8m from a charge q1=4.8x10^-19C. What is the velocity of the electron?
U=q1V
V=kq2/r
Potential energy change U. coulomb's constant k=9x10^-9, electron charge q2=1.602x10^-19C, electron mass m=9.11x10^-31kg, kinetic energy Ek=½mv²
U=k(q1)(q2)/r=6.912x10^-21J
set U=Ek => v=(2U/m)^0.5=1.23x10^5m/s
Anyone see where I went wrong? Thanks.
Redo this, paying attention to the power of ten.
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
