Distance & Distance Thrown of a Dart
  • Thread starter Thread starter Kpgabriel
A dart is thrown horizontally with an initial speed of 8.9 m/s and hits the dartboard 0.20 seconds later, impacting point Q below point P. The discussion focuses on calculating the vertical distance PQ and the horizontal distance from the thrower to the dartboard. Participants clarify that the final vertical velocity should be calculated at the moment of impact, rather than when the dart is embedded in the board. The relevant kinematic equations are emphasized for solving the vertical displacement and horizontal distance. The conversation highlights the importance of correctly applying these equations to arrive at the correct values for PQ and the thrower's distance from the board.
Kpgabriel
A dart is thrown horizontally toward the bull's-eye, point P on the dart board in the figure, with an initial speed of 8.9 m/s. It hits at point Q on the rim, vertically below P 0.20 s later.
a) What is the distance PQ?
b) how far away from the dart board did the dart thrower stand?
x=xi + .5(vi+vf)t
vf^2= vi^2 + 2a(xf-xi)
I am not really sure how to begin this problem. I know the knowns are
vi = 8.9 m/s
t= 0.20 s
vf = 0 m/s
And I believe I need to use one of the kinematic equations.
Can we start with the basics. What do those Relevant Equations represent, and where should they be used ?
To help a bit further, ##v_f## is not zero. We want velocity when the dart arrives, not when it's embedded in the board.
I got the distance away from the board solved but I do not think that final velocity is needed to find the y-component from P to Q. Instead, I tried to solve for the variables related to y and got.
vi = 0m/s
a = -9.8 m/s^2
t = 0.20s
Δy = ?
Okay, so what equation should be used, that you can plug those numbers into to get your Δy.
you were right about the velocity. I found it with respect to y using v = vi +at and then substituting into Δy = .5(vi+vf)t which gave me the answer.
k, as long as you didn't use the same ##v_i## in 'a' as 'b'. You could have gone straight to ##d=v_it+at^2/2##
