A person takes a trip: Find the time spent on the trip, etc.
  • Thread starter Thread starter Alexanddros81
    Time
The discussion revolves around calculating the total time spent on a trip and the distance traveled, given a driving speed of 89.5 km/h and an average speed of 77.8 km/h, including a 22-minute rest stop. Participants clarify that the rest stop should be included in the total time calculation, emphasizing the need for a system of equations to solve for distance and driving time. A correction is noted regarding the calculation of distance during the rest period, indicating a minor rounding error. The conversation suggests that a more efficient approach to the problem could be taken by directly incorporating the average speed and rest time into the initial calculations. Overall, the thread highlights the importance of accurately accounting for all time components in speed and distance problems.
Alexanddros81
A person takes a trip, driving with a constant of 89.5 Km/h, except for a 22.0-min rest stop.
If the person's average speed is 77.8 Km/h,
(a) how much time is spent on the trip and
(b) how far does the person travel?
This is problem 13, Chapter 2 from Serway Physics for scientists and engineers Volume 1 9th edition
[/B]
Is my solution correct?
When you wrote $$V_{avg} = {89.5 t_{a \to b} + 89.5 t_{b \to c} \over t_{a \to b} + t_{b \to c} + t_{rest}}$$, that was correct but I think they mean to include the rest stop in the time taken.
I disagree with your numbers. It makes no sense to to split the time interval into 3 parts because it doesn't matter when the driver rests. For all you know, the driver can start 22.0 min late and have no rest stop and it wouldn't make a difference to the average speed and the distance traveled. The average speed is $$v_{avg}=\frac{D}{t_{rest}+t_{drive}}$$where ##D## is the total distance traveled. You also have a second equation relating ##D## and ##t_{drive}##. The two equations comprise a system of two equations and two unknowns, ##D## and ##t_{drive}##, that you have to solve.
Likes Alexanddros81
Yes, your solution is correct with the small correction that 77.8 * (22/60) = 28.53 not 28.008. That’s just some sort of round off error, but I can’t spot where or why it is so big.
I think you could do this much more succinctly effectively jumping right to the middle of your calculation by appropriate logic. What you arrive at third line from the bottom of part a:
(tdrive+ 22 min) * vavg = tdrive * vdrive
seems readily apparent and could easily have been written as the starting point of the solution.
Likes Alexanddros81
@kuruman :
thanks. The following is written according to your suggestion. Does it seem ok?
Your numbers agree with mine.
Likes Alexanddros81
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
