Optimizing Flight Path: Accounting for Wind Speed and Direction
  • Thread starter Thread starter TNewC
    Flying Plane
A pilot flying north at 48.5 km/hr needs to adjust for a light eastward wind of 0.85 km/hr. To counteract the wind, he should head his plane at an angle of approximately 1 degree west of north. This adjustment can be calculated using trigonometric functions, specifically the tangent function, to form a right triangle with the wind and flight speeds. The consensus among participants confirms that the angle is indeed 1 degree. This solution effectively accounts for the wind's influence on the flight path.
TNewC
A pilot flying his plane...
A pilot is flying his plane 48.5 km/hr northward. He has forgotten to factor in a light wind from the east, going 0.85 km/hr. At what angle should he head his plane to factor in the wind?
I don't know :(
Well, I tried using some trig functions, and I got 1 degree, but I don't think that's right, and am now totally lost. Please help!
I tried some trig too and got 1 degree west of north also... do you have any model answers at all?
i think it must be 1 degree. Just try to draw the situation, you should get right triangle and then use tan(angle)=v(wind)/v(plane). But in order to neglect the wind pilot must head his plane at north east
Thanks so much guys! I checked with my teacher and it was indeed 1 degree. I just didn't think that would make any sense, so I asked you guys. Thank you!
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
