A question about radioactive decay
In a mixture of two radioactive species with disintegration constants of λ and λ/3, the long-term behavior reveals that species B will dominate due to its longer half-life. As time progresses, species A decays significantly faster, leading to its near-complete disappearance. The mean life of the mixture effectively becomes that of species B, as it is the only significant species remaining. The discussion emphasizes that even a small difference in decay rates can result in one species prevailing over time. Ultimately, the mean life of the mixture aligns with the characteristics of the surviving species.
ubergewehr273
Two species of radioactive atoms are mixed in equal numbers. The disintegration constant of first species is ##\lambda## and that of second species is ##\frac \lambda {3}##. After a long time, the mixture will behave as a species with mean life ________.
##\lambda=\frac{0.693} {t_{1/2}}##
##t_{mean}=\frac{1}\lambda##
What I did was to equate the mean life of mixture being the average of the mean lives of the individual species.
$$t_{mean}=\frac{\frac{1} \lambda + \frac{3}\lambda} {2}$$
However in this article https://en.wikipedia.org/wiki/Half-life it says that ##\frac{1} {t{eff}} = \frac{1} {t_{1}} + \frac{1} {t_{2}}## where ##t_{eff}##,##t_{1}## & ##t_{2}## are half lives of mixture, species A and B respectively.
Actually the question can be answered from the equations you gave without calculating a combined mean life. After a long time, which of the two species will dominate?
Species dominates as in amount of nuclei ? Then should be species B
How so?
If you have two quantities, ##a(t)## and ##b(t)##, which decay exponentially:
##a(t) = Ae^{-k_a t}##, ##b(t) = Be^{-k_b t}##,
then the ratio of the quantities, ##\frac{a(t)}{b(t)} = \left(\frac{A}{B}\right)e^{(k_b - k_a )t}##, will approach either zero or infinity when ##t\rightarrow\infty##, depending on whether ##k_a > k_b## or ##k_b > k_a##.
Based on only this, you can deduce that if two mixed radioactive species have even a small difference in half-life, one of them will be the only significant species after a long enough time has passed.
Correct. So after a long time, species B dominates and basically all of species A has decayed away. So it isn't really a mixture any more, it is only species B. So what then is the mean life?
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
