Solve Wave Moving w/ Constant Acceleration: Hi Guys!
  • Thread starter Thread starter Psi-String
    Wave
A vertically suspended string with linear density experiences a wave generated from its bottom that moves with constant acceleration. The tension in the string is proportional to the distance from the bottom, leading to a wave speed of v = √(gx), where g is the acceleration due to gravity. As the wave travels upward, its acceleration is determined to be a = g/2, indicating it increases at this rate. The analysis highlights that the wave's behavior changes near the end of the string due to the assumptions of the model breaking down. Overall, the wave's motion is characterized by constant acceleration as it propagates through the string.
Psi-String
Hi guys, here's the question.
A string, which has linear density \mu, is suspended vertically. Someone produces a wave from the bottom of the string. Please prove that the wave is moving with constant acceleration
My solution:
let x be the distance between a point on the string and the bottom of the string then
T= \mu x g where T is tension
so
v= \sqrt{ \frac{T}{\mu} } = \sqrt {gx}
then
a= \frac{dv}{dt} = \frac{dv}{dx} \frac{dx}{dt} = \frac{1}{2} g
Am I right or wrong? I'm not sure this really works.
Could someone sovle this problem by other mathematical approach, and tell me why the wave move with constant accleration qualitatively?
Thanks in advanced!
My solution:
so
then
The wave analysis breaks down close to the end since the conditions assumed in the analysis (particularly no resistance to changing shape) no longer apply.
But imagine a long heavy cable hanging with its lower end free. Plucking the cable at the middle sends a pulse that travels up the cable at a speed of v = \sqrt{gx} which increases at the rate of g/2 = 4.9m/sec^2 as it travels up the cable. The pulse traveling down the cable starts at the same speed downward but slows at the rate of g/2.
AM
I see. Thanks!
