Resultant Magnitude & Direction: 158.98 N, -86.04° E of S
  • Thread starter Thread starter cowgiljl
    Vector
The discussion focuses on calculating the resultant magnitude and direction of two forces, F1 and F2, with specific angles. The calculations initially presented yield a resultant of 158.98 N at -86.04° east of south. However, participants suggest re-evaluating the component addition, emphasizing the importance of correctly identifying the x and y components. They recommend drawing the vectors head to tail and labeling components clearly to avoid confusion. Overall, there is a consensus that a more accurate approach may lead to a resultant closer to 50 N directed southeast.
cowgiljl
It wants me to find the magnitude and direction of the resultant
F1 = 75.0 Newtons, 25 degrees east of north
F2 = 100 Newtons 25 degrees east of south
i drew a picture again
I took the for F1 sin 25 * 75 and got 31.69
F2 cos 25 * 75 and got 67.97
Sin 25 * 100 = 42.67
cos 25 * 100 = 90.63
So then i added the 31.69+(-42.67) = -10.98
and added 67.97+90.63 = 158.60
used the C^2 = A^2 + b^2 C^2 =158.60^2+10.98^2
C = 158.98 N
Tan -1 (158.60/-10.98)
and theata was = to a -86.04 degrees east of south
is that one right?
I think you should double-check how you added the components. The x-component of the force (if we label east as x and north as y) should by (F1+F2)sin(25) and the y-component of the force should be (F1-F2)*cos(25). From your diagram, you should ree that the resultant vector points roughly ESE
One of the ways to add verctors is to draw them head to tail with each other. You might not get an exact answer, but it often makes it easy to check your answer.
I suspect that you aren't keeping track of which component is which well enough.
You might do better if you drew them in and labled them x1 y1 and x2 y2 for F1 and F2 respectively. It would also make it easier for others to follow your work.
From looking at the excercise, I would guess that the resultant force should have a magnitude of about 50N and be pointing roughly southeast
You might find that it helps YOU (not to mention us) if you labeled these better. The 31.69 and 42.67 you got using sin(25): is that "east-west" or "north-south". Once you are sure of that, think about which ways the forces are in the "same direction" and which opposite.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
