I About the existence of Hamel basis for vector spaces
cianfa72
TL;DR Summary
Does an Hamel basis always exist in any specific instance of a vector space?
It is well known that a vector space always admits an algebraic (Hamel) basis. This is a theorem that follows from Zorn's lemma based on the Axiom of Choice (AC).
Now consider any specific instance of vector space. Since the AC axiom may or may not be included in the underlying set theory, might there be examples of vector spaces in which an Hamel basis actually doesn't exist ?
It can be shown that if the Axiom of Choice is false, then there are vector spaces with no Hamel basis. The exclusion of the Axiom of Choice means the exclusion of the proof based on the Axiom of Choice and this does not mean there are vector spaces with no Hamel basis. Every vector space has a Hamel basis.
Ah ok. So your claim is that every vector has an Hamel basis even though it can't proved without assuming the Axiom of Choice (AC). Basically the exclusion of the AC rules out just the proof based on it but not the conclusion (i.e. every vector space has an Hamel basis).
A ⇔ B
The exclusion of A does not produce B is false.
It is known that the axiom of choice (in its full power) is equivalent to the statement that any vector space has a basis. For finite dimensional spaces, we don't need choice to be able to produce a basis. Without choice, there is no hope for a basis in ##\mathbb R_\mathbb Q## for example. Even moreso, without choice, there is no reasonable way to define dimension for an arbitrary vector space (e.g when there are bases* of different cardinalities). One could say the space is infinite dimensional, if it cannot be generated by finitely many elements and leave it at that.
* by a basis I mean a minimal generating subset here
Also strictly speaking, I don't know if not(AC) is sufficient to guarantee a vector space without basis, maybe something stronger is required. But ##\mathbb R_\mathbb Q## is an infamous example of one where you can't get a basis without choice, but that doesn't yet imply it has no basis.
Gavran said:
A ⇔ B
The above ##A \Leftrightarrow B## is a if and only if (iff). I'm not sure how it fits in the discussion.
The Axiom of Choice and the existence of a Hamel basis imply each other.
Not sure to get the point. From the iff implication the existence of Hamel basis is equivalent to AC is True.
Maybe the key point is that claiming AC is True or False is a different matter from excluding it from the underlying set theory employed. In the latter case, let me say, we can say nothing about it (neither True or False since it doesn't exist at all).
Does the above make sense ?
The argument is if AC is false, then the statement "every vector space contains a minimal generating subset" is also false. Therefore, there exists (at least one) a vector space such that none of its linearly independent subsets are generating. .. but can we find an explicit example of one?
The answer to the post #8: Yes, it does.
Ah ok. Basically your are saying that to pick a basis for ##\mathbb R_\mathbb Q## without assuming AC as True you can't. However that doesn't imply a basis for it doesn't exist at all.
How can we be sure that a basis for ##\mathbb R_\mathbb Q## actually exists?
If AC is false, then there's no guarantee this is one of those vector spaces without a basis. Of course it's clear, a generating subset has to be uncountable, because countable subsets can only ever span countable subsets over ##\mathbb Q##. But now you're in the uncountable territory, it's very difficult to do much of anything without (some form of) choice.
Sorry, the point I'm having trouble in understanding is that, I believe, ##\mathbb R_\mathbb Q## for instance either has or has not an Hamel basis, regardless of whether the Axiom of Choice is included in underlying set theory or not.
A different matter is to give a proof of the fact that ##\mathbb R_\mathbb Q## has an Hamel basis.
Yes, a statement is either true or false. The best we have in this instance is that it is consistent with ZF that R over Q does not have a basis.
In similar vein, it is consistent with ZF that every subset of R is Lebesgue measurable (as a consequence of R being a countable union of countable sets). Is it actually true? Who knows, but if it was true, then you won't get into trouble. It is not possible to exhibit a non measurable subset without (some kind of) choice.
Let me check my understanding. Consider the statement "R over Q doesn't have an Hamel basis". Is it true ? Who knows, what we can say is that with ZF (not including AC) one won't be able to exhibit an Hamel basis for it. In this sense "R over Q doesn’t have an Hamel basis" is consistent with ZF.
Likewise, since without AC one isn't able to exhibit a non measurable set, the sentence "every subset of R is Lebesgue measurable" is consistent with ZF (AC nor included).
Sorry, does what discussed above have anything to do with Godel's incompleteness theorems?
I don't think it does, Gödel's theorem is about consistency and completeness, roughly stating that you can't have both if your theory is "rich" enough (ZF is rich enough). Regardless, if there was some way to demonstrably show in ZF alone that R over Q (or some other weird vector space) has no basis, then it would also have to be true in ZFC, which is a contradiction.
Just to reiterate what you said. Suppose in the context of ZF set theory (i.e. without throwing in the AC) there was some way to prove that R over Q has no Hamel basis.
Then, since by including the AC axiom (taken as True of course) turning ZF into ZFC can be proven the existence of Hamel basis for R over Q, there would be a contradiction (since the statement "R over Q has an Hamel basis" can be either True or False regardless of ZF or ZFC.)
I believe the topic discussed in this thread is well addressed in R. Penrose's book "The Road to Reality".
In chapter 1, he discusses "mathematical truth" as an objective truth that, let me say, "lives" in the Platonic world. For instance, he offers the example of Fermat's statement, namely
The issue is the objectivity of the Fermat assertion itself, not whether anyone’s particular demonstration of it (or of its negation) might happen to be convincing to the mathematical community of any particular time.
The point he's making is that there exist true statements having a Platonic existence as mathematical assertions, regardless of the correctness of the argument (or the rules of mathematical acceptability of the arguments) employed to prove them.
Coming back to the OP, does the statement "R over Q doesn't have an Hamel basis" exists in the Platonic world/sense ?
Who knows...what we can say is that, by using ZFC set theory, we are able to advance an acceptable mathematical argument to show its truth.
This reminds me of how puzzled I was, when writing my first algebra book, by this question: find a vector basis of the product of a countable number of copies of the rational (or real) numbers. I.e. consider the space V of all sequences of rational numbers. This is much simpler than the space of real numbers, which is a quotient of the subspace W of convergent sequences of rationals. Anyone can find a basis of the space of finite sequences (i.e. eventually zero), namely (1,0,0,0,....), (0,1,0,0,0,....) (0,0,1,0,0,0,...),......, but infinite sequences,..????? The Zorn argument says they exist, but so what?? how does that help me understand them?
mathwonk said:
Anyone can find a basis of the space of finite sequences, namely (1,0,0,0,....), (0,1,0,0,0,....) (0,0,1,0,0,0,...),......, but infinite sequences,..????? The Zorn argument says they exist, but so what?? how does that help me understand them?
Yes, this video addresses exactly the point you made.
Oh it gets much worse than that. Consider the statement "there is a cardinal number strictly between ##|\mathbb N|## and ##|\mathbb R|##. ZFC alone can neither prove nor disprove this (Gödel & Cohen). A basis for that sequence space exists, is uncountable and good luck determining anything else about it. How "uncountable" is it? Who knows. Can we recursively enumerate all its elements? Very funny.. :smile:
If you want choice, then you'll have to give up something for it. Constructivity. (Infinite) choice is as nonconstructive as it gets.
Well, statements may be undecidable. Does the Solovay model exclude choice?
As far as I can tell, ##|\mathbb N|## and ##|\mathbb R|## denote the cardinality of sets ##\mathbb N## and ##\mathbb R## respectively.
Ok, you mean within ZFC formal theory (i.e. no from the "outside") the proposition/statement ##\varphi## "there is a cardinal number strictly between ##|\mathbb N|## and ##|\mathbb R|##" or its negation ##\lnot \varphi## is unprovable.
I suspect there are models in which there are intermediate cardinalities.
Likes Gavran and nuuskur
Sorry, could you be more explicit? Thanks.
In FOL , First Order Logic, here with ZFC, statements are true/decidable, iff they are true, satisfied in all models. He used forcing techniques to extend a model of ZFC where AC held, to another one where it didn't ; he showed such sets exist in the larger model , but didn't actually construct a set of Reals with such cardinality in this model extension. Thus CH is not satisfied in all models . Is that what you're asking?
Edit: By contrast, Sentence Logic is Decidable. You can show this through Truth Tables. It's a finite process by which you can conclude whether a Wff holds or not.
https://en.wikipedia.org/wiki/Forcing_(mathematics)
Wff's are Syntactic, i.e., strings of symbols formed by precise rules, but without any assigned meaning. Interpretations, models, are Semantic, i.e., have a specific meaning assigned to them which must meet certain conditions, properties.
Sorry, let me try to show my understanding: classic FOL is sound and complete (by Godel completeness theorem) hence a FOL wff is syntactically provable (i.e. a theorem) iff it is valid (i.e. True in every model/interpretation).
Decidability is another matter. FOL is semi-decidable in the sense that only valid wffs are decidable (i.e. there is a procedure/process that confirm any one of them without running forever).
Who is your He and what is CH ?
Holds in bold applies to semantics, i.e. a sentential/propositional logic wff holds iff it is a tautology (always True regardless the truth-value assignment to propositional variables entering the wff).
Sorry, CH is 'Continuum Hypothesis ' . ' He' is Paul Cohen, who used the Technique of Forcing to extend a model of ZFC where CH holds into one model where it does not hold. Sentence Logic is decidable through Truth tables, where the truth of a wff can be verified algorithmically, and it's sound too.
