Accelration & special relativity.
In summary: D') relative the moving reference frame.In summary, under the conditions of constant proper acceleration in a rest frame, the equations of "Hyperbolic motion" can be derived, where the final speed, time elapsed, acceleration, and distance are all related by the Lorentz transformation and the Lorentz length dilation factor. However, this mathematical result does not correspond to anything useful in the real world and does not represent motion under the influence of a constant force.
Mononoke
I have a couple of questions, I'd be most grateful if someone could help me? Assume that you are accelerating at ate 'a' relative to a rest frame for distance 'D' which is also measued relative to the rest frame.
1) Is it right to use v=[tex]\sqrt{2aD}[/tex] to find the find velocity, and D=1/2at[tex]^{2}[/tex]. to find final velocity and time elapsed relative to the rest frame. I'm fairly sure this is correct.
2) what is the final speed(v'), time elapsed(t'), acceleration(a') & distance(D') relative the moving reference frame.
I'd be very happy you someone show a derivation as well. Thanks
No, it is not correct. The above is valid only in Newtonian mechanics, where F=m*dv/dt.
In relativity, you start with F=dp/dt where p=mv/sqrt(1-(v/c)^2)
m=rest mass
t=coordinate time
v=v(t)
If F is constant, you will end up with the equations of "Hyperbolic motion".
Here is a sketch for the derivation:
F=m*d/dt(v/sqrt(1-(v/c)^2)
so,
F/m=d/dt(v/sqrt(1-(v/c)^2)
Since F/m is constant(we call this "coordinate acceleration", a), the above becomes a very simple differential equation with the solution:
v=at/sqrt(1+(at/c)^2)
For at<<c, you recover the Newtonian equation v=at
If you integrate one more time, you will get x as a function of a and t. Indeed:
dx/dt=at/sqrt(1+(at/c)^2)
x(t)=c^2/a*(sqrt(1+(at/c)^2)-1)
Again, for at<<c, you recover the Newtonian formula x(t)=at^2/2
Starthaus, you're answering Mononoke's question as if the proper acceleration were constant. Mononoke posed the question by saying that it's the acceleration measured in the rest frame that's constant. If all quantities are measured in the rest frame, then the standard Newtonian equations like x=(1/2)at^2 are all correct.
Mononoke, you need to realize that under the conditions you've posed, (1) the person who's accelerating feels an acceleration that diverges to infinity as v approaches c, and (2) the accumulated energy expenditure also diverges to infinity.
No, it is for constant coordinate acceleration. Please read the derivation carefully. Please look at the definition of F/m in the text.
Starthaus, what have I done wrong with rest frame calculation. And isn't bcrowell correct since I'm measuring in a rest frame. I thought this question was conceptually a little difficult for me to grasp because the object is moving in non inertial frame and lambda is difficult to define.
No, constant coordinate acceleration would be defined as d^2x/dt^2=constant, where x and t are measured in the rest frame. Constant F/m (where m is the invariant mass and F is the force measured in the rest frame) does not produce constant coordinate acceleration, since Newton's second law is only a low-velocity approximation.
In your #2 you're claiming to derive equations that simultaneously represent constant coordinate acceleration and hyperbolic motion. That's incorrect. Hyperbolic motion corresponds to constant proper acceleration, not constant coordinate acceleration in a rest frame: http://en.wikipedia.org/wiki/Hyperbolic_motion_(relativity)
I didn't read your derivation, but what you said in the quote is wrong. The world line is a hyperbola when the proper acceleration is constant. When the coordinate acceleration is constant, the usual Newtonian stuff applies. It can't be constant for very long, because the coordinate speed can't reach c, but as long as it is, there's no need to mention force, momentum, etc.
Lorentz boosts are symmetric in the sense that if A sees B as moving at velocity v, B sees A as moving at -v. Therefore you have v'=-v. To relate D' to D, you can simply use the Lorentz length dilation factor. I believe the relationship between a and a' is also simply a factor of gamma, since the longitudinal component of force and momentum transforms that way. To get the elapsed proper time:
[tex]\int ds = \int \sqrt{dt^2-(atdt)^2}=\int\sqrt{1-a^2t^2}dt[/tex],
which comes out to be (t*Sqrt[1 - a^2*t^2])/2 + ArcSin[a*t]/(2*a), according to integrals.com.
The physical interpretation is a whole different matter. I doubt that this mathematical result corresponds to anything interesting or useful in the real world. It does *not* correspond to motion under the influence of a constant force -- the force that produces this motion is a varying one, both in the rest frame and in the accelerating frame.
Yes, I agree with this.
Thanks, but how did you get that integral
I'll have to respectfully disagree. See here for an identical derivation. I am quite sure the paper was peer-reiviewed and published. Perhaps we are disagreeing on the terminology of "hyperbolic motion" but the math is correct.
Nobody said anything was wrong with your math. Mononoke asked about motion with constant coordinate acceleration. The Iorio paper isn't describing motion with constant coordinate acceleration, and it doesn't claim to describe motion with constant coordinate acceleration.
There are three steps. Which step are you asking about?
sorry. I want to know where you get this from:
[tex]\int ds = \int \sqrt{dt^2-(atdt)^2}[/tex]
We're in flat spacetime, using Minkowski coordinates, so [itex]ds^2=dt^2-dx^2[/itex], where ds is interpreted as the proper time. Since the coordinate acceleration a=dv/dt is constant, we have v=at, and dx=(dx/dt)dt=at dt.
Sweet I got it
Mononoke said:
Sweet I got it
Cool :-)
By the way, welcome to Physics Forums.
...which is precisely what my mathematical proof is about.
I will have to respectfully disagree with you again. Please look at the opening sentence of paragraph 2 in the Iorio paper where he describes the basic notions.
...which is precisely what you will obtain if you differentiate twice wrt the coordinate time t the expression I have derived in a previous post, i.e. x(t)=c^2/a*(sqrt(1+(at/c)^2)-1)
Yes, the rest frame of an inertial observer. See also the start of paragraph 2 of the Iorio paper.
Nothing to do with Newton's second law, it is basic math. If F is constant in an inertial frame (I really don't know what you call the "rest frame", you will need to explain) and m is the proper mass, then F/m is a constant that is generally called coordinate acceleration, as opposed to "proper acceleration" (the acceleration felt by a comoving observer).
The wiki page is very badly written. Just take my final equation:
and you can easily obtain the standard equation of hyperbolic motion expressed in coordinate distance (x) and coordinate time (t), where a, as a parameter, is the coordinate acceleration:
((ax/c^2)+1)^2-(at/c)^2=1
Dear Fredrik,
I would have to respectfully disagree with you. Just take the final equation from my derivation:
and you can easily obtain the standard equation of hyperbolic motion expressed in coordinate distance (x) and coordinate time (t), where a=F/m, as a parameter, is the coordinate acceleration:
As a mathematician, I am quite sure that you will appreciate the above proof, even if it is somewhat terse.
I don't see anything in the paper that says what you seem to think it says.
This doesn't make any sense to me. Are you intending a to be treated as a constant in taking this derivative? If so, then you clearly aren't going to get a constant by taking the second derivative of this expression with respect to t.
"The equation of motion of a particle of mass m acted upon by a force F,
as viewed in an inertial frame I,"
"Note that t denotes the proper time of a standard clock located at the origin
of I."
Now, it is pretty obvious that I is not the frame comoving with the accelerated object.
d^x/dt^2=d/dt(dx/dt)=a
Nobody said that it was. What you're missing here is that the motion described by the Iorio paper is not motion with constant coordinate acceleration.
Here is the derivative, as evaluated by the computer algebra system Maxima. It does not equal a. Either we're miscommunicating, or you need to review your calculus. The most general function whose second derivative with respect to t is a constant a is a function of the form (1/2)at^2+c1t+c2.
Code:
(%i5) diff(a*t/sqrt(1+(a*t/c)^2),t);
                                               3  2
                             a                a  t
(%o5)                 --------------- - -----------------
                            2  2             2  2
                           a  t          2  a  t      3/2
                      sqrt(----- + 1)   c  (----- + 1)
                             2                2
                            c                c
It is motion with F/m=constant. I have been telling you this from the first post. I made the unfortunate mistake of calling F/m coordinate acceleration. You may choose the call that "proper" acceleration, this is fine by me. This is the origin of our disagreement, a naming convention. My math is correct.
Sorry, this was an obvious typo, it is clear from post #2 that
so,
a=d/dt(v/sqrt(1-(v/c)^2) (exactly as in the wiki page)
You are getting rude. Good bye.
1. What is the difference between acceleration and special relativity?
Acceleration refers to the rate at which the velocity of an object changes, while special relativity is a theory that explains how objects with different velocities experience time and space differently.
2. How does acceleration affect time and space according to special relativity?
According to special relativity, as an object's velocity increases, time slows down and the object's length in the direction of motion appears to decrease. This effect becomes more significant as the object approaches the speed of light.
3. Can acceleration cause an object to travel faster than the speed of light?
No, according to special relativity, the speed of light is the maximum speed at which any object can travel. As an object approaches the speed of light, its mass increases infinitely and requires an infinite amount of energy to accelerate further.
4. How does special relativity affect the concept of simultaneity?
According to special relativity, simultaneity is relative and can be different for observers in different reference frames. This means that two events that appear to happen simultaneously for one observer may not appear simultaneous for another observer in a different reference frame.
5. What are the practical applications of special relativity?
Special relativity has many practical applications in modern technology, such as GPS systems, particle accelerators, and nuclear power plants. It also plays a crucial role in understanding the behavior of objects at high speeds, such as spacecraft and satellites.
