Adding and subtracting thermalchemcial equations help needed
  • Thread starter Thread starter chemistry4all
    Subtracting
The discussion focuses on calculating the heat of reaction for equation C) using the enthalpies of reactions A) and B). The user attempted to manipulate the equations by multiplying and reversing them, but arrived at an incorrect enthalpy value of -849.7 kJ for equation C), while the expected value based on standard enthalpy of formation for water should be -725.46 kJ. Participants pointed out that the user may have miscalculated the addition of enthalpy values and emphasized the importance of ensuring all reactants and products are correctly accounted for in the overall equation. The user is encouraged to double-check their calculations and the application of thermodynamic rules. The discussion highlights the complexities of thermochemical calculations and the necessity for accuracy in each step.
chemistry4all
From the enthalpies of reaction for equations A) and B), calculate the heat of reaction for equation C).
A) 2H2 (g) + O2 (g) ----> 2H2O2 (g) DH= -483.6 kJ
B) 3O2 (g) ----> 2O3 (g) DH= +284.6 kJ
c) 3 H2 (g) + O3 (g) -----> 3H2O (g) DH= ? kJ
NONe
My attempt is as follows:
I multiplied equation A) by 3 first including the DH as well and got and flipped equation be so the 2O3 can cancel out.
A) 6H2 (g) + 3O2 (g) ----> 6H2O (g) DH= -1450.8 kJ
B) 2O3 (g) ------> 3O2 DH= -284.6 kJ
adding A) + B) I got
6H2 (g) + 2O3 (g) -------> 6H2O (g) DH= -1699.4 kJ
since i need to get to c) 3 H2 (g) + O3 (g) -----> 3H2O (g) all I did is divide everything by 2 including the DH = -1699.4 kJ
the DH came out to for equation C) as -849.7 kJ and this is not correct because the enthalpy for H2O (g) is -241.82 and since there are 3 H2O it should be -725.46 which I can't seem to get.
Can someone please help where I have made a mistake? Thanks
What does it mean that the enthalpy of H2O(g) is -241.82? Does not it refer to a reaction from the elementary constituents, H2 and O2?
ehild
the -241 is from the data table of standard formations of enthalpy but in this problem it does not want me look it up it wants me to calculate it using the two equations. The answer should be double the -241 but its not coming out that way. I think I did something wrong and I have tried everything to see what I did wrong. Can't seem to figure it out.
Anyone please help?
as ehild said, the 242 you've quoted is probably from standard constituents.
For H2O, this is probably H2 and 1/2 O2, not O3.
but C) asks for H2 + O3.
I know this is wrong because the first equation if you look at the standard formation of enthalpies chart is correct and so is the number for O2 ----> O3 is correct with the proper coeffients that are already in front of it. So mathematically the equation A and B should add up be able to get to equation C right?
As far as I know these are the rules:
1) All the reactants in the overall equation must appear on the left side.
2) All the products in the overall equation must appear on the right side.
3) All reaction intermediates (those not present in the overall equation) must appear on both sides equally so they are canceled out.
4) You sum up the individual equations (just like a standard addition problem) to make the overall equation.
5) A reaction written in reverse of the direction given in the problem must have the sign of its enthalpy changed.
6) A reaction multiplied by a coefficient in order to balance the overall equation must have its enthalpy multiplied by the same coefficient.
I did exactly the rules above unless I miss something.
Check your addition in this last step. Otherwise, your procedure is correct.
Your argument about getting 3x the enthalpy of H2O is not valid, as others have pointed out.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
