Adding two sinusoidal waves of same frequency but out of phase
The discussion focuses on the mathematical derivation of the sum of two sinusoidal waves with the same frequency but differing phases. It begins with the expression Asin(wt) + Bsin(wt + φ) and uses the trigonometric identity sin(a + b) to expand it. The result is simplified to the form Csin(wt) + Dcos(wt), where C and D are defined in terms of A, B, and φ. The relationship between these coefficients is further explored using Pythagorean identities, leading to the conclusion that the sum can be expressed as Esin(wt + θ). The conversation emphasizes the importance of understanding the underlying trigonometric principles to derive the final expression accurately.
souky101
Adding two sinusoidal waves of same frequency but out of phase - Does the resultant wave form still pure sinusoidal with same frequency?
Asin(wt) + Bsin(wt+a)
Asin(wt)}+Bsin(wt+a)
Asin(wt) +B sin(wt)cos(a) +Bcos(wt)sin(a)
Asin(wt) + ksin(wt) + Lcos( wt)
(A+K) sin(wt) + Lcos(wt)
Fsin(wt) + Lcos(wt)
It can be deduced to the form of
C\sin(\omega t+\phi)
Thanks for your reply
But how you can drive it mathematically
You started out OK. It's mostly based on the trig identity you used ##sin(a+b)=sin(a)cos(b) + cos(a)sin(b)##
So:
##Asin(\omega t) + B sin(\omega t + \phi) =##
##Asin(\omega t)+B(sin(\omega t)cos(\phi)+cos(\omega t)sin(\phi)) =##
##(A+Bcos(\phi))sin(\omega t)+Bsin(\phi)cos(\omega t) \equiv Csin(\omega t)+Dcos(\omega t) ##
where ##C \equiv A+Bcos(\phi)## and ##D \equiv Bsin(\phi)##
since sin(x) and cos(x) are orthogonal, we can used Pythagoras to simplify to
##Asin(\omega t) + B sin(\omega t + \phi) = \sqrt{C^2+D^2}sin(\omega t + \theta)##
where ##\theta = tan^{-1}(\frac{D}{C})##
The last bit comes from working that original identity in reverse:
Assume the answer has the form ##Csin(\omega t)+Dcos(\omega t) \equiv Esin(\omega t + \theta)##
Then ##Esin(\omega t + \theta) = E cos(\theta)sin(\omega t)+Esin(\theta)cos(\omega t)## from the identity.
This means ##C \equiv Ecos(\theta)## and ##D \equiv Esin(\theta)##
Then note that ## C^2+D^2=E^2cos^2(\theta)+E^2sin^2(\theta)= E^2## so ##E=\sqrt{C^2+D^2}##
Also ##\frac{D}{C} = \frac{Esin(\theta)}{Ecos(\theta)} = tan{\theta}##
Likes FactChecker and Delta2
Let us equate them as
F \sin \omega t + L \cos\omega t = C \sin (\omega t + \phi)
Expanding RHS you see
F=C \cos \phi, L=C\sin \phi
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
