Adiabatical Compression Question
  • Thread starter Thread starter Reptic
    Compression
Air at 20°C is compressed adiabatically from 1 bar to 10 bar, raising its temperature. The ideal gas law (PV = nRT) requires using an absolute temperature scale, such as Kelvin, for accurate calculations. The first law of thermodynamics is relevant in this context, and it's important to consider whether the compression is reversible. The discussion emphasizes the need for correct temperature units and thermodynamic principles in solving the problem. Understanding these concepts is crucial for determining the final temperature after adiabatic compression.
Reptic
Air at 20C is compressed adiabetically from 1 bar to 10 bar. What will its temperature be?
pV = nRT,
P1P2=T1T2
P1Vλ1=P2V2λ
In picture...[/B]
Is PV = nRT valid for the Celsius temperature scale?
no, should be kelvin 293 right?
Yes, you need to use an absolute temperature scale such as Kelvin.
Are you familiar with the first law of thermodynamics? Are you supposed to assume that the compression takes place reversibly?
Chet
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
