Aircraft Direction to Fly North: Solve Airplane Problem
  • Thread starter Thread starter Throwback24
    Airplane
To achieve a resultant direction of due north while flying at a cruising speed of 100 m/s against a 75 m/s eastward wind, the pilot must point the aircraft at an angle to the west. The problem involves vector addition, where the wind vector and the plane's velocity vector must be combined to yield a zero x-component for the resultant. The angle θ can be determined using the inverse cosine function, arccos(0.75), which helps find the necessary heading against the wind. The displacement after 1.25 hours can be calculated using the resultant velocity. Understanding inverse trigonometric functions is crucial for solving similar vector problems.
Throwback24
An aircraft has a cruising speed of 100 m/s. On this particular day, a wind is blowing from the west at 75 m/s.
If the pilot wishes to have a resultant direction of due north, in what direction should the plane be pointed? What will be the plane displacement in 1.25 h?
I answered the other two parts of the question asking for the total displacement and velocity relative to the air or something. Where do I start with this?
I know it has to do with polar positives but my textbook has no examples.
Isn't it just a vector addition problem?
They give you 1 vector - the wind (direction,magnitude) and they give you the resultant (direction, but not magnitude) and they give you the plane speed magnitude but not direction.
In the X direction, It's
75 Wind = -75 for Plane = 100*Cosθ because the resultant has no X component.
So isn't θ found by the acrCos(.75) = θ where θ is with respect to the -x axis?
Then in the Y direction it's |Resultant| = 100*Sinθ
Then of course your displacement after 1.25 hrs is 1.25 * |Resultant|
If the wind is blowing from the west doesn't that mean it's going east? Thus positive?
acrCos(.75)
What does this mean?
Thank you.
acrCos(.75)
Thank you.
Yes the wind is going to the east, but you must fly the plane to the west against the wind at an angle to go north.
The arcCos is sometimes written as Cos-1(.75)
Given the value of the Cosine θ, it returns the value of θ.
Go to Google and enter "arccos(.75) in degrees".
You should familiarize yourself with the inverse trig functions as they will be useful in figuring the angles in a number of these kinds of vector problems.
