Algebra & Physics: When Rules Don't Apply
  • Thread starter Thread starter madah12
    Algebra Physics
The discussion centers on the application of algebra in physics, particularly in the context of the photoelectric effect. It highlights the confusion surrounding the relationship between energy (E), kinetic energy (K), and the work function (Φ), emphasizing that Φ is a constant specific to the material. The participants clarify that doubling the energy of photons does not lead to a simple doubling of kinetic energy, as the equations must account for the work function. They conclude that while algebra is applicable, the relationships between the variables must be understood correctly to avoid misinterpretations. Ultimately, the conversation reinforces the importance of accurately applying mathematical principles in physics.
madah12
When does the rules of algebra not apply in physics?
I mean in photo electric effect E = K + \Phi right?
and phi is a constant
so if we have twice the energy 2E = 2K + 2 \Phi
and then E2=K2 + \Phi2
and then \Phi2 = 2E1 - 2K1
\Phi2 /2 =E1-K1 = \Phi2/2 = \Phi1 so phi changed...
but phi is a constant right dependent only on the type of material so it won't change? (I have very little knowledge in photo electric effects this is mainly how and when algebra does not apply in physics)
Sorry I noticed that I didn't write everything when I made the original post so my argument made no sense I edited it .
It's like if you feed one puppy and one kitty on one, well, cake (!?), your puppy and kitty are full; then if you want to throw away 2 cakes in a meaningful way (:biggrin:), then you must get another puppy and another kitty, so 2 puppies and 2 kitties totally for 2 cakes :wink:
If we understand one cake as E, one kitty as K and one puppy as P (let P denote phi, I'm lazy), then actually P2 = 2 puppies. That is, puppy is still puppy, it doesn't grow bigger or smaller, just the number of puppies increases. Likewise, P2 doesn't stand for the work function; P2 is the amount of energy given up by 2 electrons, while P1 (or P) is the amount of energy given up by 1 electron. It's just that we define the work function = the amount of energy given up by 1 electron, or simply P.
EDIT: In conclusion, algebra in particular and math in general concur with physics (or is it the way around, that physics concurs with them? :rolleyes:). I mean, in this case, math does apply.
Umm thanks for the reply. But I shamefully say that I didn't get it completely I mean let say we want the kinetic energy K2 we know where we increased the energy of the photons
we know the values of E , K , phi in the original case and we doubled E
by using another type of light
would K be doubled and phi? I mean we didn't change anything in the material it self but phi can't be doubled because it is constant so the algebriac equation won't hold right?
because unless K2=2K1 and phi2 = 2phi 1 , E2 won't be equal to 2E1
Ah, I see. So that really is a problem with math. I mean, your math :frown:
So first you have an electron with kinetic energy K, so you need a photon of energy E. The relation is: E = K + P. Then if you want another electron with 2K, then what you need is NOT a photon of energy 2E! That is, if you shoot a photon of energy 2E, you won't get an electron of 2K.
(1): In order to get an electron of 2K, what you need is a photon of (2K + P), which is NOT equal to 2E.
(2): If you shoot a photon of 2E, what you get is an electron of (2E - P), which is NOT equal to 2K.
And what the mathematical equation 2E = 2K + 2P means, I have already explained. That is the case when you shoot 2 photons of E and consequently, get back 2 electrons of K. This case is not the same as the two cases (1) and (2) above.
Ok I get it now thanks.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
