Algebraically determine the max height the snowball reaches
To determine the maximum height of the snowball, the function h = -4.9t^2 + 20t + 1.8 can be analyzed as a quadratic equation. The maximum height occurs at the vertex of the parabola, which can be found by completing the square or using the vertex formula t = -b/(2a). Substituting this value back into the height equation will yield the maximum height. For the time the snowball is in the air, set h to zero and solve for t. The discussion emphasizes that calculus is not necessary for finding the maximum height.
lauren
my teacher gave me this q:
a snowball if thrown into the air. The function h= -4.9t^2 + 20t + 1.8 expresses the relationship between height, h, in meters and time, t, in seconds.
a) algebraically determine the max height the snowball reaches
b) how long is the snowball in the air?
i know to solve b you just need to plug in your h and solve for t. however for part a, i am not sure how to solve the max. can someone help?
Mathematics news on Phys.org
Do you have an equation for the velocity of the projectile as a function of time?
If not, do you know that velocity is the derivative of position with respect to time?
In either case, note that the ball reaches its maximum height when the velocity is zero.
no, all the info i got to solve this q i posted
Have you studied calculus?
h= -4.9t2+ 20t+ 1.8 is a quadratic. Its graph is a parabola with vertex at the top. Complete the square to find the vertex. You don't need to use calculus.
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Imaginary Pythagorus'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
