Increase Strength with Aluminium: 30x30mm to 60x60mm and 3mm to 6mm
  • Thread starter Thread starter Rado Gary
    Aluminium Strength
The discussion focuses on the strength differences in aluminum angles when changing dimensions and thickness for a radio mast project. The original query compares a 30mm x 30mm x 3mm angle to a 60mm x 60mm angle and considers the impact of doubling the thickness to 6mm. Key points include the importance of loading conditions and end constraints in determining strength, with suggestions for structural calculations to ensure safety under heavy antenna loads and high wind speeds. The user is seeking expert advice on material selection and structural integrity for a telescopic mast design. The conversation highlights the need for detailed specifications to provide accurate strength assessments.
Rado Gary
Could anyone please help me?
If I have a piece of aluminium Angle that is 30mm x 30mm by 3mm thick and 1m long, if I were to substitue this with a piece that is the same thickness and length but 60mm x 60mm what increase in strength would I see?
If instead of increasing the size what would happen if I doubled the thickness to 6mm thick?
Please please help...
Rado Gary: That depends on how it is loaded. You have not specified how it is loaded yet. Also, you have not specified end constraints. The ends are pinned (simply supported), right? Is this a school assignment?
Bending strength? Tensile strength? What loading? If it is in bending, did you think about looking at reorientation of the L shape cross section in relation to the deflection?
Many thanks for the comments, I see I need to provide some more information.
I am a Radio Amateur and am looking to build a radio mast. I need this to be telescopic and cope with a heavy antenna around 220kg that also has a high wind loading of around 28 square feet.
In the Uk there is nowhere that manufactures radio towers as one offs to accommodate this kind of antenna, so I have decided to embark on this complex project myself.
If you have the time you might look at a German website www.hummelmasten.de here you will see the type of mast I am trying to replicate.
I would be prepared to discuss this project and my needs in more detail if someone wanted to provide me with structual calculatons for the mast. I would be prepared to pay for their advise and design calculations.
I need the mast to extend to around 30m (100ft) and cope with the antenna loading at windspeeds of up to 85mph.
So looking at what i have seen others use I am looking to build the mast out of equal angle aluminium and I am just pondering as to the differences in strength the same sectional aluminium piece would have if it were substituted for different thickness.
The lattice mast sections will be bolted together and each telescopic section will be 6m in length.
So my initial thoughts were to use 4inch equal angle 7075 T6 aluminium for the bottom section and this material would be 12mm thick. The dimensions for this being 780mm square.
The second section being around 610mm square and utilising the same size alumnium angle but I was wondering as to what effect to the strength of the overall secton would have if I reduced the material thickness to 6mm?
So a long winded explanation I know but why I am asking what effect the variations on material selection would have.
Now can anyone help me?
Kind Regards
Gary
My iitial thoughts are h
Rado Gary: A single structural angle (pinned-pinned column) with dimensions 102 x 102 x 12 x 1000 mm is 1.94 times stronger than the 102 x 102 x 6 x 1000 mm angle.
http://towermast.willburt.com/products.asp
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
