How do eddy currents affect magnet movement through non-magnetic materials?
In summary: L1QVWxVt0In summary, there are a few considerations when choosing between a PVC or aluminum tube for building an actuator with a solenoid and plunger. Aluminum can intensify the magnetic field, but the plunger may stick to it. Steel, on the other hand, has a higher permeability and can increase the available force. However, using aluminum may also result in dissipation due to eddy currents being induced when the plunger moves in the tube. This effect may be desirable or undesirable depending on the application. It is also important to consider the thickness of the tube and the strength of the magnet being used. Overall, experimentation may be necessary
Bern123
Hi, what differences are if i use a pvc tube to build an actuator(solenoid with plunger) or alluminium? Alluminium can intensify magnetic field? but the plunger will stick with alluminium? or solenoid will have less force?
Why not use steel? The permeability of steel will increase the force available. Aluminium is non-magnetic.
The plunger is in steel. I don't know how tube may influence in positive or in negative. I always see actuator in pvc tube.
The aluminum may increase the dissipation. Eddy currents will be induced every time the magnetic field changes. This change will happen when the plunger moves in the tube, for example.
Think about the experiment with a magnet falling in a copper or aluminum tube. The steel core will be magnetized, so it is a magnet moving in a conducting tube.
The damping may be a desirable effect, after all. It depends on the application.
See this, for example:
Your tube has much thinner walls, I suppose. So the effect will be much weaker.
But some dissipation will be there so why not avoid it, if you have no special reason for aluminum?
I wondered about that but would it be a significant effect unless the actuator was being driven in-out-in-out continuously (or fed with AC, of course)?
It will be an effect (don't know how strong) only when the actuator moves. Or actuates.:)
Isn't this when it matters?
Oh, you mean there will be no power dissipation when it does not move.
You are right. I was more concerned about a damping of the motion itself rather than the power lost in the tube.
So, if i need high speed applications, alluminium will not be good?
I have no idea how strong the effect will be for your specific tube.
And high-speed is a relative concept.
Only trying you can find out.
A nice demonstration of non-magnetic materials and eddy currents:
1. Use a strong magnet - the modern neodymium magnets works well; for a flat magnet use a flat piece of aluminum - wide enough and long enough to work as a slide.
2. Show that the magnet is not attracted to the aluminum
3. Place the aluminum slide flat on the table, with the magnet at one end
4. Now slowly lift the magnet end of the slide; the magnet will begin to move down the slide ...
5. But as the angle of elevation increases, the magnet will slow down - due to the induced eddy currents. This is "magnetic braking".
A thicker aluminum slide makes for a more dramatic effect.
So for your solenoid I would avoid a metallic enclosure if the magnet is strong.
This site describes some other demonstrations; but the video didn't work for me:
https://www.kjmagnetics.com/blog.asp?p=eddy-currents
This video shows the demonstration of a magnet falling through a copper tube:
1. What is an aluminium tube for solenoid?
An aluminium tube for solenoid is a hollow cylindrical structure made of aluminium, used in the construction of solenoid valves. It serves as the housing for the solenoid coil, which is responsible for generating the magnetic field that controls the flow of fluid through the valve.
2. What are the benefits of using an aluminium tube for solenoid?
Aluminium is a lightweight and durable material, making it a cost-effective and efficient choice for solenoid valve construction. It is also resistant to corrosion, allowing for a longer lifespan of the valve. Additionally, aluminium has good thermal conductivity, ensuring efficient heat dissipation from the solenoid coil.
3. How do I choose the right size of aluminium tube for my solenoid valve?
The size of the aluminium tube for a solenoid valve will depend on the specific requirements of the valve. Factors to consider include the flow rate, pressure, and fluid compatibility. It is important to consult with a reputable manufacturer or supplier to determine the most suitable size for your application.
4. Can an aluminium tube for solenoid be used in high-temperature applications?
Yes, aluminium tubes for solenoid can be used in high-temperature applications. However, the temperature range will depend on the specific grade of aluminium used. It is essential to ensure that the aluminium tube is compatible with the temperature requirements of the solenoid valve.
5. Are there any alternatives to using an aluminium tube for solenoid?
Yes, there are other materials that can be used for solenoid valve construction, such as stainless steel, brass, and plastic. However, aluminium is a popular choice due to its lightweight, durability, and cost-effectiveness. The choice of material will depend on the specific requirements and conditions of the application.
  • Other Physics Topics
  • Electromagnetism
9K
  • Electrical Engineering
