Are the Amplitude and Period Calculations Correct for This Tsunami Model?
  • Thread starter Thread starter tennistudof09
    Track
The discussion focuses on calculating the amplitude and period of tsunami waves modeled by the equation y = 8 sin(pi/6)t. The amplitude is confirmed to be 8 feet, while the period is calculated as 12 minutes. For the velocity of the wave, given a distance of 21 kilometers between crests, the correct calculation yields a speed of 105 km/hr. This contrasts with an earlier incorrect estimate of 15.75 km/hr. The calculations are validated, confirming that the approach to solving the problem is accurate.
tennistudof09
Am i on the right track?
We have this problem for math class:
For an interval of 45 minutes, the tsunamis near Hawaii caused by the chilean earthquake of 1960 could be modeled by the equation y= 8 sin (pi/6)t, where y is in feet and t is in minutes.
a) find the amplitude and period of the waves b) If the distance from one crest of the wave to the next was 21 kilometers, what was the velocity of the wave?
I know the amplitude is 8 and 2pi/ (pi/6) came out to be 12, so I got 12 for the period. For question b, in order to get the velocity, should i just do 21 x (.75)?
You should add units to the numbers you found. For example, the amplitude is 8 feet. The period is 12 whats?
If the distance from the crest of one wave to the next is 21 km, that has to relate to the period somehow.
so therefore i would convert 12 minutes into hours, which allows me to get .2 hours. Then since velocity is distance/time, i'd get 21km/.2 hr, and would give me a solution of 105 km/hr. Did I do that correctly?
Looks good to me. The wave crests are 21 km apart, and it's .2 hour between crests, so the wave is traveling at 105 km/hr. Notice that this is a lot different from your first answer, which was 15.75 km/hr.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
