Ampere's Law: Explained and the Role of Magnetic and Electric Fields
Ampere's Law explains the relationship between electric currents and the magnetic fields they generate, with the magnetic field outside a current-carrying wire following the right-hand rule due to conventions based on observed forces between charges. The geometric configuration of circular magnetic fields arises naturally from the properties of electromagnetism, and while alternative conventions could exist, they would not change the underlying physics. The discussion touches on the relativistic effects of moving charges and the nature of magnetic fields, suggesting that these phenomena are inherent traits of the universe. Observations, such as patterns formed by iron filings around a wire, help in understanding and mathematically describing these fields. Ultimately, the conversation emphasizes the importance of geometry and observation in the study of electromagnetism.
physics user1
I know the ampere's law but I want an explanation on why it exist in that way, consider a wire where flows current, i know that when an observer is in relative motion to the current there is a magnetic field but why in this geometric configuration and not in another? What about the electric field outside? I guess is zero unless we don't move at the same velocity on the current so that our frame of reference is solidal with it, then the electromagnetic field is just electric field, is that TRUE? I mean, if we see current flowing all the field is magnetic, if we don't see current all the field is going to be electric due to Lorentz contraction law and all that stuff right?
Why the magnetic field outside a wire obeys to the right hand rule?
Can you focus your question down to one most important key question? You have so many scattered questions that you will get scattered responses.
Why does the magnetic field outside the wire carrying current obey to the right hand rule, why does it formes circumferences around the wire?
That is just a convention. We could have chosen a left handed convention and all of the physics would have worked out the same.
We don't observe the magnetic field directly. Instead we observe the forces between current-carrying wires and moving charges. Our rules for the direction of the magnetic field produced by a current (or moving charge), and the force exerted by a magnetic field on a current (or moving charge) were chosen so as to accommodate our observations of the forces between currents and moving charges moving at various angles with respect to each other.
As Dale noted, we could use a "left-hand rule" for the magnetic field if we also used a matching "left-hand rule" for the magnetic force exerted by that field. Mathematically, this would be equivalent to putting minus signs in the two equations, which would cancel out when we combine them.
Back up a step - why does charge in motion cause a magnetic field at all ?
P
Is a relativistic effect
an observed trait of the universe
What if it'd been hexagonal instead of circular ? The formulas would be a little different, that's all..
Likes physics user1
So... it's like that because the universe is made this way
That would imply a very arbitrary case of symmetry. If it had to be a hexagon pattern, would the sides of hexagons for different wires all be parallel from wire to wire? It would imply 'preferred' directions in space which would be very unsatisfactory for Mathematicians, if nothing else (lol). The circle is the least arbitrary pattern in this case. Geometry is a pretty powerful argument here, as it is when you justify the Inverse Square Law.
Likes Dale
I think so.
Place iron filings around a wire and observe the pattern.
Then figure out what math describes it.
http://hyperphysics.phy-astr.gsu.edu/hbase/magnetic/biosav.html
Scientific method:
Observe something.
Then figure out what math explains the observations.
Then see if the math ever fails, and when it does adjust it.
Isn't that how relativity came about ?
I think if i understood what magnetism really is i'd have a nice lab at Princeton.
old jim
Likes physics user1
hmmmm would preferred directions infer that dreaded "absolute frame of reference" ?
