A sphere has a radius of 5 m. How many 5cm diameter spheres can it contain?
  • Thread starter Thread starter Power of One
    Volume
To determine how many 5 cm diameter spheres can fit inside a sphere with a radius of 5 m, the volumes of both spheres are calculated using the formula for the volume of a sphere. The large sphere's radius is converted from meters to centimeters, resulting in a volume calculation of 4/3π (500)^3. The volume of a single small sphere is calculated as 4/3π (2.5)^3, leading to an initial estimate of 8,000,000 small spheres. However, this estimate is unrealistic due to the packing efficiency of spheres, which must be considered for an accurate calculation. Understanding the concept of close-packing is essential for resolving this discrepancy.
Power of One
Volume of a sphere= 4/3π r^3
5m=500 cm
volume of large sphere/ volume of small sphere
4/3π (500)^3/ 4/3π (2.5)^3
=8,000,000 spheres
This answer doesn't seem reasonable. What am I doing wrong?​
