Angualar Acceleration of swinging rod
  • Thread starter Thread starter scarletcrimso
    Acceleration Rod
The discussion revolves around understanding the relationship between torque and angular acceleration in the context of a swinging rod problem. Participants are seeking guidance on how to approach the problem, emphasizing the need for hints to get started. The key concept highlighted is that torque is directly related to angular acceleration, as described by Newton's second law for rotation. Clarification on how to apply these principles to the specific problem is requested. Overall, the conversation focuses on foundational physics concepts necessary for solving the homework question.
scarletcrimso
http://img76.imageshack.us/img76/7109/questionol2.jpg
Hi, I have really been stuck on this problem for a while. My problem is that I have no idea where to start, any hints or guidance would be much appreciated it.
Thank you for your time.
Hi scarletcrimso,
What is the relationship between torques on an object and angular acceleration of that object?
