Angular Acceleration of a grinding wheel
The discussion focuses on calculating the angular acceleration and maximum angular velocity of a vertical grinding wheel with a specific mass and radius. For part (a), the initial angular acceleration is calculated to be approximately 9.31 rad/s², with some participants suggesting slight variations in the moment of inertia value used. In part (b), the maximum angular velocity is found to be 3.32 rad/s, but there's a correction needed regarding the height from which the weight drops, which is 0.69 m instead of the wheel's radius. Participants are encouraged to review their calculations, particularly regarding the torque and height in the context of the problem. Overall, the thread emphasizes the importance of accurately applying physics equations to solve for angular motion.
spirited
A vertical grinding wheel is a uniform disk of mass 62 kg and radius 45 cm. It has a handle of radius 69 cm of negligible mass. A 25-kg load is attached to the handle when it is in the horizontal position.
(a) Neglecting friction, find the initial angular acceleration of the wheel in rad/s^2.
(b) Find the maximum angular velocity of the wheel in rad/s.
I = 1/2MR^2 + mr^2
t = mgr for torque
a = t/I for angular acceleration
mgr = 1/2Iw^2
a) Neglecting friction, find the initial angular acceleration of the wheel.
9.31 rad/s^2
I found I which is 18.18 kg m^2 using the above equation.
I then gound T(t) which is 169.23 Nm
a = t/I = 9.31 rad/s^2
(b) Find the maximum angular velocity of the wheel.
I used mgr = 0.5Iw^2 and got w = 3.32 rad/s
***What am I doing wrong?? I know both are wrong answers. I think I am doing something wrong for part a. Please help!
Thanks
Welcome to PF.
I think for a) your method is OK. I calculate 9.2 m/s2
with I = 18.38 but let's not quibble too much over that.
For b) though I think you are overlooking that the 25 kg weight has dropped .69 m and not the r of .45.
I understand it now...Thanks.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
