Angular Momentum: Clarifying a Problem
The discussion focuses on calculating the angular momentum of a particle with a mass of 0.01 kg rotating at an angular speed of 2 rad/s in a circle of radius 0.8 m. The initial calculations provided suggest that the rotational inertia (I) is 0.0064 kg*m^2, leading to an angular momentum of 0.128 kg*m^2/s. However, there is a correction regarding the units, as the correct unit for angular momentum should be kg*m^2/s, excluding radians. The clarification emphasizes the importance of using the proper units in physics calculations.
fro
Somewhat confused about this problem and need some clarification:
Problem: A particle of mass 0.01kg rotates with angular speed of 2 rad/s in a circle of radius 0.8m. What is its angular momentum?
I think the answer should be:
I = 0.01kg X (0.8m^2) = 0.0064 kg/m^2.
w = 2 rad/s.
Therefore, angular momentum = 0.0064 kg/m^2 X 2 rad/s = 0.128 kg*rad/m^2*s.
Am I on the correct path?
w = 2 rad/s.
You are correct in your calculations, but not in your units. The unit for rotational inertia is kg*m^2, which is what your math would indicate. Also, the radians are generally not included in the units for angular momentum, so you should come up with an answer in the form kg*m^2/s.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
