Angular Momentum Needed Variable Velocity
To find the speed of a block after an elastic collision with a pendulum bob, first calculate the bob's speed at the bottom of its swing using energy conservation principles. The potential energy at the top converts to kinetic energy at the bottom, yielding a speed of approximately 3.83 m/s for the bob. Since the collision is elastic and the masses are equal, momentum conservation dictates that the block will also move with the same speed as the bob just before impact. Therefore, the speed of the block just after the collision is 3.83 m/s. This problem illustrates the application of energy conservation and momentum principles in elastic collisions.
AirChambz
A steel ball fastened to the end of a 1.5 m long string to form a pendulum is
released in the horizontal position. At the bottom of its swing, the ball collides elastically
with a block of equal mass resting on a frictionless surface. What is the speed of the block
just after the collision?
http://img686.imageshack.us/img686/3459/phys.png
R=1.5m
M_ball_=M_block_
I=mr^2
L_A_=r*p*sin(theta)
L_A_=I(omega)
I did not know where to start however I tried equating I(omega)=r*p*sin(theta) since momentum is conserved the momentum of the pendulum should turn into the momentum of the block, also since the masses are equal whatever final momentum you get should be the answer
Anyway the answer turns out to be 5.4 m/s in the end just am not able to get there...
R=1.5m
M_ball_=M_block_
I=mr^2
L_A_=r*p*sin(theta)
L_A_=I(omega)
Use energy conservation to determine the speed of the pendulum bob just before it hits the block. Now you know the intitial speed of the block before the collision.
Next draw a picture: (i) the bob and the block just before the collision, and (f) the bob and the block just after the collision:
(i) means initial
(f) means final
What is conserved?
E = W + Q Q=0 -> E=W W= Fd -> W= m*g*R?
Well yes, W=mgR, but you didn't need to involve Q; this isn't a thermodynamic problem.
If gravity does mgR of work, what's the speed of the bob at the bottom of its swing?
...sqrt(14.7)? (3.83m/s) with m canceled out
This is a two-step problem.
First, determine the speed of the bob at the bottom of the swing, just before it hits the block. You can do this using conservation of energy. Work, of course, is related, but the power of energy conservation techniques lies in using path-independent potential energy functions, which are related to the work done by conservative forces.
Draw a picture (i) bob at the top of swing, and (f) bob at the bottom of swing, and apply
E_i= E_f
K_i+U_i = K_f+U_f
You'll only need the potential functions for gravity. Now you'll know the final speed of the bob, at the bottom of the swing. Now, start a new clock at (i) initial, where the bob is just about to hit the block, and then a (f) picture, after the block and bob have collided. Both the block and bob have final velocities.
What is conserved during the collision? The word "elastic" gives you a hint about one of the conserved quantities...it's in your text.
