helpppmeee
- 15
A 500 g steel block rotates on a steel table while attached to a 2.0-m-long massless rod. Compressed air fed through the rod is ejected from a Inozzle on the back of the block, exerting a thrust force of 3.5 N. The nozzle is 70 degrees from the radial line, so that the net force created by the nozzle points 20 degrees, from the tangential velocity, toward the inside of the cirlce . The block starts from rest. What is the angular velocity after 10 rev?
so i found the acceleration along the tangential velocity, used the equation; xF = xI + vI*t + 1/2(a)t^2, where xF and xI are the final and initial displacements, respectively (vI[initial velocity] is clearly zero). xF = 20*pie*radius and i found the time it takes to make 10rev. I then took the total radians in 10 rev (20*pie) and divided it by the total time. i got 10.something rad/s where the answer is actually 6.63rad/s. I also found the centripetal force after those 10 revs and tried to do the same thing, again got the same answer. helpp pleeeeasee!
