Swinging Pendulum: Analyzing Height & Distance Relationships
In summary, the conversation discusses a pendulum consisting of a string and a sphere, with the string hitting a peg located a distance d below the point of suspension. The conversation goes on to show that if the sphere is released from a height below that of the peg, it will return to this height after striking the peg. It also discusses the minimum value of d for the pendulum to swing in a complete circle centered on the peg, which is found to be 3L/5. The conversation also explores the use of the conservation of energy to solve the problem.
discoverer02
138
A pendulum comprising a string of length L and a sphere swings in the vertical plane. The string hits a peg located a distance d below the point of suspension (see attached)
A) show that if the sphere is released from a height below that of the peg, it will return to this height after striking the peg.
B) Show that if the pendulum is released from the horizontal position (theta = 90 degrees) and is to swing in a complete circle centered on the peg, then theminimum value of d must be 3L/5.
I've come up with the following equations that I'm trying to relate to show the height after striking the peg is the same as before.
The initial height is L - Lcos[the], the height after striking the peg is L - d - (L - d)cos[psi].
mgh(initial) = (1/2)mv^2(bottom of the arc)
mgh(final) = (1/2)mv^2(bottom of the arc).
I'm not sure where to go from here.
Any suggestions would be greatly appreciated.
Thanks.
The way you started the problem is not going to get you anywhere, because you used the exact same state for the initial and final states, namely the state at the bottom of the arc.
Choose instead the state at release as the initial state, and the maximum height above the peg reached by the sphere. You should be able to show that the sphere does not clear the peg, and so instead of wrapping the rope around it, it comes back to its original height.
Here you have to note what the critical condition is for the ball going "over the top". That critical condition is that the speed has to be zero at the top of the swing. Use that as your (known) final state to deduce the (unknown) initial state.
Thanks for replying.
The initial state at release of the sphere is mgh. There's only gravitational potential energy.
The maximum height reached by the sphere is:
((radius x angular velocity)^2)/2g or (velocity tangential^2)/2g.
I can't relate these using the conservation of energy, so I'm still stuck.
You've got the initial state right, so use the stopping point at the other end of the swing as the final state, and show that it cannot make a loop around the peg. Then you will know that it has to come back to its initial position.
Thanks again for taking the time to reply.
OK, the stopping point at the other end of the swing is mgh'
so if I equate the two states (does the peg steal away any energy from the system or is energy conserved?)...
mgh = mgh'
mg(L - Lcos[the]) = mg(L - d - (L - d)cos [psi])
Lcos[the] >= d
If Lcos[the] = d then (L - d)cos[psi] = 0 so either L = d or
[psi] = 90 degrees.
So if the release point is at the peg the angle the sphere makes with the vertical after striking the peg is 90 degrees.
If I assume Lcos[the] to be greater than d then I get
(L - d)cos[psi] = some positive number meaning the angle is less than 90 degrees or greater than 270 degrees.
Why do I think there's a cleaner easier way to do this?
Am I at least on the right track?
mgh = mgh'
The two heights will be the same if friction and the diameter of the peg are negligble.
I think you're thinking too hard about this. All you have to do is note that the ball cannot get "over the hump" of swinging around the peg. Since the ball can't get to the point directly over the peg, it can't go over.
Thanks Tom,
That makes part b) simple
At the top the sum of the centripetal forces = mv^2/R
so T + mg = m^2/R, but at the top T = 0
so vtop = (g(L-d))^1/2
By conservation of mechanical energy
mgL = 2mg(L-d) + 1/2mg(L-d)
2L = 4L - 4d + L - d
d = 3L/5
1. What is a swinging pendulum?
A swinging pendulum is a simple mechanical system consisting of a weight or bob suspended from a fixed point by a string or rod. When pulled to one side and released, the weight will swing back and forth in a regular pattern, known as a period.
2. How does the height of the pendulum affect its period?
The height of the pendulum does not affect its period. The period of a swinging pendulum is determined by its length and the acceleration due to gravity. This means that as long as the length of the pendulum remains constant, the period will also remain constant regardless of its height.
3. What is the relationship between the length of a pendulum and its period?
The relationship between the length of a pendulum and its period is known as the pendulum equation. It states that the period (T) is equal to 2π times the square root of the length (L) divided by the acceleration due to gravity (g), or T = 2π√(L/g). This means that as the length of the pendulum increases, the period also increases.
4. How does the mass of the pendulum affect its period?
The mass of the pendulum does not affect its period. This is because the pendulum equation only takes into account the length and acceleration due to gravity. The mass of the pendulum will affect the speed at which it swings, but not the time it takes to complete one full swing.
5. What is the significance of studying the height and distance relationships in a swinging pendulum?
Studying the height and distance relationships in a swinging pendulum can help us better understand the principles of motion and the laws of physics. It also has practical applications, such as in the design of clock pendulums and other mechanical systems that use pendulums for accurate timekeeping.
22K
