Another Linear approximation question
The problem involves estimating the change in a function using linear approximation, specifically for the function f(x) = 1/(1+x^2) at the point a = 3 with a change Δx = 0.5. Participants are discussing the calculation of the derivative, the linear approximation, and the subsequent error and percentage error calculations.
  • The original poster attempts to calculate the derivative and use it for linear approximation, while also seeking clarification on the error calculation. Some participants question the correctness of the derivative and the error percentage derived from the calculations.
Participants are actively engaging with the problem, with some providing corrections and suggestions for re-evaluating the error calculation. There is no explicit consensus on the correct percentage error, indicating ongoing exploration of the problem.
There appears to be confusion regarding the calculation of the derivative and the subsequent error, with participants noting discrepancies in the percentage error reported by the original poster.
bcahmel
stimate Δf using the Linear Approximation and use a calculator to compute both the error and the percentage error.
f(x) =1/(1+x^2) , a = 3, Δx = 0.5
f'(a)(x)
percentage error= abs(error) divided by actual value
So first I got the derivative which is -2x/(1+x)^2.
Then I plugged the a value, 3 into it which came out to be -3/50 and then multiplied it by x, 0.5, to get my linear approximation of -0.3. I understand this part.
Now to find the error, I first have to find the actual value on the calculator. So I plugged 3.5 into the original function, 1/(1+3.5^2)= 1/13.25. Is this right so far?
Plugging just 3 into the equation I get 1/10.
Now 1/13.25- 1/10 is about -.0245. This is the error, I think...
and percentage error would be .0055/-.0245=22.44% Seems high..
Basically I'm confused on the error part. I would be really grateful if anyone could straighten out how to do this!
shouldn't the derivative be -2x/(1+x^2)^2
The linear approximation gives you an estimate of f(3.5), so the error you want to calculate is
[tex]\frac{f_\mathrm{est}(3.5)-f(3.5)}{f(3.5)}[/tex]
thanks lanedance, I typed it wrong on the computer- but you're right that is the derivative.
And vela, that's makes sense. So I think I did the error part right!
The error was something like 7% or so, not 22%, so you should recheck what you did.
  • · Replies 25 ·
