Ansys Tutorials: Finding the Right Guide
  • Thread starter Thread starter Baltistani
    Ansys Tutorials
The discussion focuses on finding appropriate ANSYS tutorials for various applications, including stress analysis, fluid dynamics, and heat transfer. Users share links to several online resources that provide comprehensive ANSYS tutorials and documentation. Specific inquiries arise regarding modeling techniques in ANSYS, particularly for heat transfer and fracture mechanics, including the application of out-of-plane loading and modeling multiple cracks in orthotropic plates. Participants seek guidance on suitable elements for their projects and methods for applying moments to plates. The conversation highlights the need for targeted resources and expert advice in using ANSYS effectively for complex simulations.
Baltistani
Help needed to find proper ansys tutorial
In what particular area? Stress analysis? Fluid Dynamics? Heat Transfer?
A yahoo search that took all of about .5 sec resulted in the following:
http://www.mece.uAlberta.ca/tutorials/ansys/
http://instruct1.cit.cornell.edu/courses/ansys/
http://www.engr.uky.edu/~jrbake01/ansystutor.html
http://www.aa.washington.edu/courses/aa430/gradystutorials/toc.html
http://www.ansys.com/services/ss-self-service.asp
http://www.ansys.net/ansys/
http://www.me.cmu.edu/academics/courses/webtutor.htm
http://www.uic.edu/depts/accc/software/ansys/html/tutor_55/TUTORToc.htm
Search engines are a wonderful thing.
heat transfer
help needed to use ansys for heat transfer
ANSYS Theory Manual Online
This might be useful to nonusers of ANSYS as well as users.
http://www1.ansys.com/customer/content/documentation/90/ansys/a_thry90.pdf
2. Structures
2.1. Structural Fundamentals
2.2. Derivation of Structural Matrices
2.3. Structural Strain and Stress Evaluations
2.4. Combined Stresses and Strains
3. Structures with Geometric Nonlinearities
3.1. Large Strain
3.2. Large Rotation
3.3. Stress Stiffening
3.4. Spin Softening
3.5. General Element Formulations
3.6. Constraints and Lagrange Multiplier Method
4. Structures with Material Nonlinearities
4.1. Rate-Independent Plasticity
4.2. Rate-Dependent Plasticity
4.3. Gasket Material
4.4. Nonlinear Elasticity
4.5. Shape Memory Alloy Material Model
4.6. Hyperelasticity
4.7. Viscoelasticity
4.8. Concrete
4.9. Swelling
6. Heat Flow
6.1. Heat Flow Fundamentals
6.2. Derivation of Heat Flow Matrices
6.3. Heat Flow Evaluations
6.4. Radiation Matrix Method
6.5. Radiosity Solution Method
And much more
anything about fluid dynamics?
help needed for modeling cracks in ansys
Hi..guys..
I am doing my m.tech project on fracture mechanics..
I have to model orthotropic plate containing holes frm which 2cracks are emanating radially frm each hole.
my problem is i have to apply out of plane loading like bending moment and torsion.
So can any pls suggest for following problems
1.which element is suitable for above problem..?
2.how to model multiple cracks in ANSYS..?
3.How to apply moments over a plate..?
4.how to model orthotropic plate...?
thanks in advance...
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
