Electric Potential/Energy question
  • Thread starter Thread starter Flaming Toilet
    Electric
The discussion revolves around calculating the work required to bring three electrons within 1.0 x 10^-10 m of each other. The initial calculations involve determining the potential energy for each pair of electrons using the formula Work = q(KQ/r). The total work done to bring the electrons together is calculated to be 3.4 x 10^-18 J. Participants confirm the approach and clarify the visualization of the problem, indicating the absence of a diagram in the reference material. The calculations and understanding of electric potential and energy are affirmed as correct.
Flaming Toilet
Here's the question: "How much work must be done to bring three electrons from a great distance apart to within 1.0 x 10^-10 m from each other?"
Here's what I did :
.(work to bring one to another)
Work = PE + KE
= PE + 0
=q(V final - V initial) ; V initial = 0
=qV final
=q(KQ/r)
= (1.6 x 10^-19)((9 x 10^9 x 1.6 x 10^-19)/(1.0 x 10^-10))
= 2.3 x 10^-18 J
.(work to bring the other one)
Work = q(KQ/r)
= (1.6 x 10^-19)((9 x 10^9 x 1.6 x 10^-19)/(2 x 1.0 x 10^-10))
= 1.2 x 10^-18 J
. I then add them together to get the total work done
(2.3 x 10^-18 J) + (1.2 x 10^-18 J)
= 3.4 x 10^-18 J
Now, is that right? Feel free to correct me.
I see. I'm visualizing the question as three electrons coming together in a line. Bleh, the book didn't provide a diagram. However, I think you're right. Thanks for guiding me in the right direction.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
