Appropriate arrangement of light meter circuit with LDR and resistor question:
The discussion revolves around the arrangement of a light meter circuit that includes a light-dependent resistor (LDR) and a resistor in series with a 12V cell EMF. Participants are exploring how to effectively configure these components to measure light intensity.
  • Exploratory, Assumption checking
  • Participants are questioning the arrangement of the LDR and resistor, considering whether the LDR should be placed before or after the resistor in the circuit. There is an attempt to understand the reasoning behind this configuration.
Some participants have raised points about the lack of clarity regarding how the light meter is intended to function, suggesting that the interpretation of the readings may be crucial. There is an ongoing exploration of what variables might be measured in the circuit and how they relate to light intensity.
There is a noted absence of specific details in the original problem statement regarding the measurement method or the expected behavior of the circuit under different light conditions, leading to uncertainty in the discussion.
Caiti
If you have a series 'light-meter' circuit with a cell EMF of 12V that must include both an LDR and a resistor only (in series), which way would you put them around to make this most effective and why?
~~~That is, would you have LDR then resistor, or resistor then LDR? And what would be the reasoning for this.
n/a
If you have a series 'light-meter' circuit with a cell EMF of 12V, wouldn't the appropriate arrangement of a resistor and an LDR be to have the positive end of the battery connected to the LDR and then the resistor, as opposed to having a resistor and then LDR? I can't work out why though.
n/a
Hi Caiti, Welcome to Physics Forums.
I don't see any "meter" in your light-meter :smile: Perhaps the answer lies in knowing how one is to interpret the "reading" from this device.
Hey,
While I totally agree with your comment, this is a question I've pulled straight from a book of them - and there is definitely no additional information there. I'm assuming the exact way of measuring light was to be disregarded; however I'm obviously not certain about this.
Caiti said:
Hey,
Well, why don't you propose a method of interpreting a 'reading' from the circuit? What kinds of things might be measured in an operating circuit? Do you want your reading to be larger when there's more light, or less light? What varies in an LDR with changes in light, and how does it vary?
  • · Replies 45 ·
