Arc Length of Curve: Find Solution (-2,2) to (2,4)
sepah50
Find the arclength of the section y=x2 between points (-2,2) and (2,4)
L = \int\sqrt{(\frac{dx}{dt})^2+(\frac{dy}{dt})^2}
So what I did first is find the derivative of y=x2 which is y'=2x
So I put that into the formula and get \int\sqrt{1+4x^2} from limit point 1 to 4
From this point on I attempted to do u-substitution but it didn;t seem to work.. Anyone have any suggestions o how I can get it done?
Trig substitution works well here.
Yes, some people have told me to use Trigonometric substitution but the thing is that my teacher hasn't taught us that yet!
Represent it as:
<br /> \sqrt{1 + 4 x^{2}} = \frac{1 + 4 x^{2}}{\sqrt{1 + 4 x^{2}}} = \frac{1}{\sqrt{1 + 4 x^{2}}} + \frac{4 x^{2}}{\sqrt{1 + 4 x^{2}}}<br />
The integral:
<br /> \int{\frac{dt}{\sqrt{1 + t^{2}}}} = \sinh^{-1}{(t)} = \ln{(t + \sqrt{1 + t^{2}})}<br />
is sometimes quoted as a table integral. To my knowledge, there is no other way to prove except by those substitutions mentioned earlier, or hyperbolic ones.
The other intergral:
<br /> 4 \, \int{\frac{x^{2} \, dx}{\sqrt{1 + 4 x^{2}}}}<br />
can be integrated out by parts (and using some elementary substitutions). Good luck!
Well, basically here's how it works. Let's say that...
2x=tan(\theta)
Then this is also true.
2 dx = sec^2(\theta) d\theta
Just plug those values in for dx and 4x^2=(2x)^2 and then you have a new integral in theta.
But don't forget to change your bounds too.
2x=tan(\theta)
Thanks for the advice, it is much appreciated! What I found out is that I can use the integral table and use this formula: http://www.sosmath.com/tables/integral/integ11/integ11.html" It is #8 of this list. Would that work?
