Are there any short term courses available on aerodynamics?
Short-term courses on aerodynamics are sought after, with a reference to a NASA resource provided for further exploration. A recommended book on the subject is 'Mechanics of Flight,' specifically the 9th edition, which is suggested as a valuable resource. The discussion also includes a request for the author's name of the recommended book. Participants are encouraged to share additional resources or recommendations. Overall, the thread focuses on finding accessible learning materials in aerodynamics.
harpreet singh
Can some1 tell me r there any short term courses available on aerodynamics or can anybody refer me a good book...
In my opinion, the best book on aerodynamics is 'Mechanics of Flight'. I prefer the 9th edition. You might get that in the library.
Cheers,
-Brittt
Britt could you tell me the author of this book you are referring
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
